Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: RG11? Compatible with Directv, thoughts?
  1. #1
    Join Date
    Nov 30th, 2006
    Posts
    11
    Post Thanks / Like
    I've heard some good things about RG11 coax over long runs. Is this compatible with Directv?
    Thought about using this with my over the air antenna and possible with my sat.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Oct 22nd, 2004
    Location
    Binghamton, NY
    Posts
    4,014
    Post Thanks / Like
    The RG11 will work just fine. It has less loss per foot than RG6.
    HR23-700, HR24-500/AM21, Samsung UN46C6500
  4. #3
    Join Date
    Sep 13th, 2007
    Location
    40 miles west of chicago
    Posts
    252
    Post Thanks / Like
    yep, should work fine, it is 75 ohm like either rg6 or 59. If you have a cheap source I would use it. Not sure how much help it would be on the satellite lines, Would probably help more for weak OTA reception. How long of a run are we talking?
  5. #4
    Join Date
    May 21st, 2006
    Posts
    445
    Post Thanks / Like
    Quote Originally Posted by HDhysteria View Post
    May also want to consider the voltage drop.
  6. #5
    Join Date
    Oct 22nd, 2004
    Location
    Binghamton, NY
    Posts
    4,014
    Post Thanks / Like
    Right. The voltage drop is real important for the switching voltages sent to the LNBs.
  7. #6
    Join Date
    Aug 22nd, 2006
    Location
    Bainbridge Island, WA
    Posts
    1,722
    Post Thanks / Like
    The center conductor is larger, so there will be less voltage drop in addition to lower loss using RG11. Both the cable and suitable connectors (compression, of course) are more difficult to find and a different compression tool is required.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
