Quantcast
signal quality on ONN
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 6 of 6
  1. #1
    Join Date
    Mar 17th, 2005
    Posts
    859
    Post Thanks / Like
    Up until a few days ago I could hit high 90s to occasionally 100 on ONN on Gal. 17 I heard that horizons 2 was taking it's place and Gal. 17 was moving to take the place of Gal. 11 Since then about the best signal I get from ONN is 50. I can't get any signal on G10R. Has anyone else experienced a decrease in Ku signals on ONN or does my dish need some peaking?
    I'm also getting no KU signals on Gal 11
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    May 6th, 2005
    Location
    Metro New Orleans, LA
    Posts
    6,271
    Post Thanks / Like
    I am assuming this is a motorized installation (since you refer to G-10R, which is across the arc from Galaxy 17). If you are getting nothing on G-10R (on any transponder), then your arc is probably off. Has there been a storm with heavy winds lately? Can you get any other satellites between these two?
    Current systems: 3X GEOSATpro microHD PVRs; Digitrans DTE-7150 DVB/Digicipher II; SiliconDust HDHomeRun ATSC/QAM networked tuners; fixed 1 meter Channel Master dish with Eagle Aspen P870 FSS stacked Ku LNB; 2X 3ABN 36" dishes with Sadoun KBSL1 stacked Ku LNBFs on Powermax SG-9120B H-H motors; fixed Sadoun SD180G 1.8 meter dish with Eagle Aspen B1SAT stacked C LNBF; Winegard Square Shooter OTA DTV antenna
  4. #3
    Iceberg's Avatar
    Iceberg is offline The No Pain Train
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Nov 17th, 2003
    Location
    A Chicken Farm in Sandy Fork, Delaware
    Posts
    86,424
    Post Thanks / Like
    ONN did drop a little bit but that is normal. It fluxuates all the time but to not get G10 means the motorized is not 100% set up right
    Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
    All FTA stuff in storage right now
  5. #4
    Join Date
    Mar 17th, 2005
    Posts
    859
    Post Thanks / Like
    Thread Starter
    Hey guys, thanks for your replies. Yes it's a 10 ft motorized C/KU setup. It's tracking the arc for C band just fine. On G10R I can get the outdoor channel 2 HD with quality in the 90s. We have had some wind yes. I also can't get any KU signal from Galaxy 11. I have read on here that G10 is dying. I also have read that horizons 2 is replacing Gal. 17 while, G17 moves over to take the place of Gal. 11. I figured if these sats were dying maybe that's why the signals are weak so, I wanted to find out if anyone else was having problems. I definitely think my alignment has gotten off somehow. It's gonna be about 40 here today so I'm gonna play around with it since I have the day off.
    Should I be trying to peak my True south first? It's 87W. I am noticing the PBS HD channel also has lower signal. I can receive it though. I have to bump the dish to get it. I'm sure something is out of whack.
  6. #5
    Iceberg's Avatar
    Proud Staff Member
    Join Date
    Nov 17th, 2003
    Location
    Posts
    86,424
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    yes try and peak on your true south first. C-Band is more forgiving especially on a bigger dish. My 6 footer I can get C-band great but KU can be a bugger to pull in
  7. #6
    Join Date
    Mar 17th, 2005
    Posts
    859
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Quote Originally Posted by Iceberg View Post
    Hey thanks Ice. I just went out and adjusted the elevation 1 flat. I got PBS to go from about 40 to 70 quality. ONN is high 80s. I now get good signal from G10R 70s-80s. That's up from Zero so I'd say pretty significant Galaxy 11 has gone from Zero to 75-85 on 12060 V 26700.
    Now white springs is only about 25. How strong is white springs normally? That appears to be the farthest west KU satellite I can check. If you know more, I'd love to hear it. I'm trying to make sure both ends of the arc are ok.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
