Results 1 to 6 of 9
Thread: 612 receivers with 722
02-15-2008 10:47 AM #1
I was wondering this question concerning what equipment would be needed. I would like to get a 722 and 2 612's. What else would be needed above and beyond the dish 1000 as far as switches. can you hook up these 3 receivers without the need for other equipment. I believe three receivers each need two sat inputs.
Just wondering?
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
02-15-2008 10:47 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Posts
- Many
02-15-2008 10:53 AM #2
If you have a 1000.2 dish, the LNB will have three outputs that can be used for up to three dual tuners without any additional equipment. If you;re in an area that uses the 61.5 for HD programming, you'll need a DPP44 switch, which can feed up to 4 dual tuner receivers with no problems. You can run just one satellite feed to each of those receivers and Separate them at the receiver, but you MUST use Dish Pro Plus LNB's/switches.
02-15-2008 12:34 PM #3
- Join Date
- Jul 25th, 2005
- Posts
- 27
- Post Thanks / Like
- Thread Starter
So is the 612 considered a dual tuner or a single tuner in regards to ordering new service. Can a customer get a 722 and two 612's for example when ordering new service with the specials where you see 4 tuners installed for free.
02-15-2008 09:29 PM #4
02-17-2008 07:59 AM #5
Advantage Of 612 Over 722
What is the advantage of 612 over 722? Is there a monthly price difference or is the only difference the upfront costs? Just don't understand the logic? I have 622 already hooked up to 2 HDTVs and am getting a 3rd TV and was thinking 722 unless I am missing something about the 612.
02-17-2008 08:42 AM #6
Register To Reply
