Results 1 to 6 of 8
Thread: Can I get a signal?
03-06-2008 09:04 AM #1
Can I get a signal?
I just moved into a condo in Chicago, and was looking at the TV situation. The prices for Comcast seem too expensive for my taste, but I liked the deal that Dish offered. The problem is that the condo association won't let me mount a dish on the roof, because of some "membrane" problem. I can however mount it on the balcony, but I happen to be on the first floor. There's also a rather big tree 30-40 feet or so away. I would figure the dish would have to point SW or NW to have any chance of a signal. Is there a way I can check if I could get a signal without having to waste some installers time? Also, if I can get a signal, does the 29.99 hd package include my RSN (comcast sportsnet hd)? Thanks
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
03-06-2008 09:04 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Posts
- Many
03-06-2008 11:04 AM #2
The dish will need to point SW and you need a open line of sight. The signal actually hits the top of the dish at about a 45 angle, not the direction the dish appears to be pointing. There is not really a sure fire method, your best off to just order and let the tech try and get it installed.
03-06-2008 11:34 AM #3
Non Penatrating mount
I am assuming from you post your apartment has a flat roof. (that is usually the case why they would use a membrane) anyway. you can get a non penetrating mount for your dish. This is basically a flat metal tray with a couple of concrete blocks on it to keep it from moving. I am an installer and I use these all the time for Apartments. Call up Dish and tell them that then the installer can talk to your apartment management.
03-06-2008 11:53 AM #4
Actually, there is a pretty darn close method using a handy little plastic gizmo that most installers have access to. You line it up with its built in compass and level and it will show you where the satellites are.
So you know, the elevation in Chicago is around 36.5 degrees, not 45.
03-06-2008 02:34 PM #5
I used a drafting triangle as a "quick and dirty" sight tool. 30,60,90. I stuck the short side against a bathroom window right below where I wanted to mount the dish outside, used a compass to point it in the right direction, and sighted up the long side.
Hey, don't laugh too hard. It worked.
03-06-2008 03:46 PM #6Yeah but the OP doesnt have that little nifty tool does he? Nor does he ask for elevation specs. All I gave him a general idea how to figure the line of sight he needs. Its not a sure method and its too hard to tell without seeing the site so thats why I said to call a installer to be sure.
ADVERTISING BOX
So that YOU know, I dont care what the elevation of Chicago is.Last edited by WiCkeDuDe; 03-06-2008 at 04:14 PM.
Register To Reply
