Quantcast
Moteck SG2100 Motor
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 6 123 ... LastLast
Results 1 to 6 of 31
  1. #1
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    Moteck SG2100 Motor
    The SG2100 DiSEqC motor mount is a low cost unit that lets you move your dish from one satellite to another or across the whole Clarke belt, it can move 70 degrees E and W of your true south position. It was a breeze to set up, if you take the time and care to get the pole or mast as plumb and level as you possibly can an extra five minutes spent here can save you 50 minutes later in the project, the manual is not the greatest but the angles to set the mount and the antenna declination are all included, to assist in the set up there is now
    an easy to read document
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    that you can look at, it will save a lot of time and really helps in the installation. (see below)
    The first time I installed one it took about an hour I now have it down to about fifteen minutes including a scan of the arc. On the whole its the next best thing to a blind search receiver and has saved many trips to the roof to re-point in the middle of winter. Talking about winter, if the dish gets covered in snow I motorize round into the sun and it soon melts off, another trick is to motor the dish to the far East or West when the wind picks up and it lowers the profile of the antenna system. There is also no need to run any more cables to power the motor as it runs off the single RG6 cable that runs from the DiSEqC 1.2 receiver, I have had mine for a year now and would not consider doing without one I still get a kick out of it every time I see my dish tilt and swing to the east and west.
    DiSEqC 1.2 MOTORIZED H-H Mount
    Fits Winegard 76cm dishes and Hotdish 30"
    Special Design for any Receiver with DiSEqC 1.2
    Only One Coaxial Cable Control
    Go To X Function
    High Efficiency
    Compact Structure
    Ultra Low Noise
    Adjustable Hardware Limits
    Easy Installation with LED Indicator
    Manual EAST / WEST button
    For Dish up to 1.2M
    Specification:
    Model SG2100
    Antenna Diameter 1.2M Max.
    Azimuth Angle 70˚EAST ~ 70˚WEST ( 140˚ ) Adjustable
    Elevation Angle 25˚~75˚
    Input / Output Voltage 13 / 18 VDC
    Power Consumption 50 mA ( Standby mode )
    200 mA ( Normal)
    350 mA ( Max.)
    Rotation Speed 1.9˚ / sec ( at 13V) ; 2.5 ˚/ sec ( at 18V)
    Satellite Positions 60
    Connector F Type
    Command Protocol DiSEqC 1.2
    Resynchronize Function YES
    Goto Position 0 Function YES
    Goto X Function YES
    Positioning Sensor High Resolution Hall Effect Sensor
    EAST / WEST Limit Adjustable Hardware and Programmable Software
    Manual Button EAST / WEST
    Indicating LED YES
    color status indication
    Green On Power On; Standby Mode
    Orange Blink Receiving DiSEqC 1.2 Commands/ Reset Mode
    Orange On Error Message: Over Current / Hardware Limit
    Tube size for antenna 55x160mm
    Stand size 35~65mm
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Cascade did! Help Support The Site And Get Rid of the Syndicated Ads, Cascade did! If you enjoy the site consider supporting it, Cascade did! Be COOL like Cascade and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jun 1st, 2004
    Location
    37.134004N 76.561779W
    Posts
    1,457
    Post Thanks / Like
    I have one of the SG2100s too.
    It's built like a tank, quiet and apparently it's the fastest motor for moving between birds.
    I reckon it has to be the easiest motor to set up as it has a button on the motor itself to swing it East or West with a signal meter inline making it a breeze to hit your true South bird.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Mark_AR did! Help Support The Site And Get Rid of the Syndicated Ads, Mark_AR did! If you enjoy the site consider supporting it, Mark_AR did! Be COOL like Mark_AR and Click a Star and become a Supporting Pub Member today!
    Join Date
    Nov 17th, 2003
    Location
    North Arkansas
    Posts
    1,445
    Post Thanks / Like
    This will be my first (Newbie) motor install.
    I got the mast bolted up this afternoon. I had to elongate the holes a little on the mast to get the arm to plumb and level. Tomorrow I will probably mount the motor and try to get it pointing due S.
    So far I think I have about 15 minutes involved in assembly and mounting.
    Will let you know how the rest goes.
  5. #4
    Join Date
    Jul 19th, 2004
    Posts
    148
    Post Thanks / Like
    Motorized dish and G10
    Hi fellas!!!
    I have a motorized SG2100 and I have no trouble finding any satellite overhead. Now this motor is supposed to have horizon to horizon coverage but I can't seem to get G10. When it is pointed in the direction it looks like it is shooting throught the neighbor's fence.
    Has anyone been successful with using a motorized dish to get G10? I live in Jacksonville Florida.
    Thanks....
    MrM
  6. #5
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    Thread Starter
    Get Rid of this Ad! Register Today!
    The fence may be the problem, I get G10 no problem with my SG2100, in fact I get a lot further to the west, way past 148W, I guess it depends where you are in the country also.
  7. #6
    Iceberg's Avatar
    Iceberg is offline The No Pain Train
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Nov 17th, 2003
    Location
    A Chicken Farm in Sandy Fork, Delaware
    Posts
    86,424
    Post Thanks / Like
    ADVERTISING BOX
    Pete installed one for me about 3 months ago and I love it!
    Where I live I can motor from 34.5W all the way to 148 (of course, this takes a bathroom break to move that far)
    Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
    All FTA stuff in storage right now
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
