Results 1 to 6 of 6
Thread: rg6 coax question for a long overhead run
  1. #1
    Join Date
    Apr 5th, 2008
    Posts
    Post Thanks / Like
    I need to run some rg6 coax from my house to a tree then over a road to a post down on my beach to get the line of sight shot to the correct satellite to get my locals in HD. The run should be less than 200 ft. I need to know if there is a specific type of rg6 that I should use for this overhead application. If anyone has done a similar run what is a max length that you can run before you need to boost the signal and what type of cable should be used to hold up the weight of the cable plus any snow or ice?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Nov 5th, 2007
    Location
    Phoenix, AZ
    Posts
    3,032
    Post Thanks / Like
    Aerial coax RG6. Install a P-hook at both ends of the aerial crossing. Secure the aerial messenger to the hook by wrapping it around the hook 3 times, then over the messenger 2 times and then over the messenger coax 5 times. Depending on the nature of the road, you may have to be over 16 feet off the ground at the aerial crossing. It's something like 12' for driveways, etc. Post here what type of traffic crosses that road and if it is a private road, etc.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! rv1pop did! Help Support The Site And Get Rid of the Syndicated Ads, rv1pop did! If you enjoy the site consider supporting it, rv1pop did! Be COOL like rv1pop and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 15th, 2007
    Location
    South Central Cascade Mountains and on the road.
    Posts
    2,642
    Post Thanks / Like
    Along with vegassatellite's post::
    Our area just went to 16 over even private roads (Not "on property" driveways more than 30 feet from roads) and at least 18 feet over county roads, with additional height for snow and ice loads. National Electrical Codes are being interpreted to outlaw all wire attachments to "vegetation" (trees) although the code is for wiring over 50 volts. You may have to put up poles to cross the road. It appears you are saying it may be all private property. If so I would consider buried pipe, even 1/2 or 3/4 inch polypipe - inside heavier iron pipe under the road... but that is my way, on course I have to deal with 75 mph winds on regular basis, too (and bury 3/4 inch NMT conduit because of rodents and badgers.).
  5. #4
    Join Date
    Oct 16th, 2007
    Posts
    304
    Post Thanks / Like
    Quote Originally Posted by rv1pop View Post
    This will also save you some length (16' up and 16' down)
    its my understanding (someone correct me if I'm wrong) its not so much signal loss as it is voltage drop
    the lmb is powered by the stb and won't operate properly if you loose to much voltage in your long run
    what system do you have ? direct, dish, dish pro or pro plus
    which antenna?
    can't you use a wing dish and offset it to shoot up through the same line of sight you are using now?
    or is this a new install?
    did someone come out and say you didn't have line of sight
    get a second opinion, call a retailer
    money talks
    if its dish hd is on both the 61.5 and the 129 sats
  6. #5
    ke4est's Avatar
    ke4est is online now Long Live FTA
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Aug 9th, 2004
    Location
    Far West -- Western North Carolina
    Posts
    14,910
    Post Thanks / Like
    to Satelliteguys!!! skidoomi
    FTA---> GEOSATpro microHD, Amiko Nano HD, Mini HD SE, etc. 120" Unimesh for C-band only with Titanium Satellite C1-PLL > 55.5W to 131W, Titanium Satellite ASC-1 Controller.
    -----------GEOSATpro 90cm and Titanium Satellite PLL-1KS on Stab HH-90 motor, GEOSATpro 1.2M and SL2PLL fixed at 125W.
    DISH--> Dish America Silver Pack + Encore and Starz
    ke4est @ SatelliteGuys.US If You Want To Stay Ahead Of The Rest, Please Click Here----Always Here To Help!!
  7. #6
    Join Date
    Jan 14th, 2008
    Posts
    348
    Post Thanks / Like
    Forget rg6, rg11 would be better.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
