Quantcast
BUD maintenance
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 3 of 3
Thread: BUD maintenance
  1. #1
    Join Date
    Sep 24th, 2004
    Posts
    24
    Post Thanks / Like
    BUD maintenance
    Have not had time in awhile for this hobby until now
    I am at 39 *45' x 94*50, my south is G3C
    I have checked all my angles on the BUD (polar axis 40.21, declination angle 5.51 and apex elevation 44.29), which appear correct.
    There are no analog signals on G3C but I get 45% signal strength to my Pansat 2100A. (I have a Coolsat 6000 which will be put into the loop once I get this working again
    Scan the digital side from The List and get nothing
    I am thinking bad LNB?
    I noticed tonight that there is a light on the Ku LNB, does this indicate signal or power? I am guessing power, which might mean that the Ku LNB is good and possibly the C LNB is bad? Of course if that is the issue I may need to fine tune Ku?
    Any other things to check?
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Sep 10th, 2005
    Location
    Northern USA
    Posts
    765
    Post Thanks / Like
    did you turn the bud on the pole, until finding signal? is the skew correct? focal point on the lnb?
    45% on level or quality? level should be 75% or higher always, if level is lower you have bad cable or lnb. Quality is the actual satellite signal level.
  4. #3
    Join Date
    May 1st, 2008
    Posts
    28
    Post Thanks / Like
    ADVERTISING BOX
    Quote Originally Posted by st_moose View Post
    Cover the feed with your hand. If the light goes out, it is signal strength. If the light stays on, it is power. Sony used to make a DTV dish that had an LED on it. When connected to a receiver, the LED would light when the dish was pointed at a satellite (nice feature for the installer).
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
