Results 1 to 6 of 6
Thread: 3abn dish and motor?
06-03-2008 04:55 PM #1
Has anyone had any luck adapting the 3 abn dish to a motor?
what kind of modifiations are needed?
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
06-03-2008 04:55 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
06-03-2008 04:56 PM #2
I didnt think it needed any modifications...there is a bunch of people here who have a motor and 3ABN dish
Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
All FTA stuff in storage right now
06-03-2008 05:09 PM #3
No modifications were required to install the 3ABN on the Sadoun DG-380 motor, it did require the 42mm motor tube (50 mm comes standard with the motor). Working great so far.
C-Band: 12' Unimesh/AJAK 180/GeoSat C2***10' "Perfect 10" mesh/GeoSat C2*** 8.5' Birdview solid/BV H-H/GeoSat C2*** 7.5' Unimesh/CalAmp voltage-controlled LNBF***...C-Band LOS from 58W-139W
Ku-Band: 3ABN .9m/SL1PLL LNBF/SG2100***Fortec .9m/TrackerII LNBF/STAB HH90***7.25' Birdview "Spoon"/TrackerII/70:1 BV H-H***Prodelin 1.8m/GeoSat Bullet/AJAK 180 H-H***Paraclipse Hydro 1.5m Prime Focus/Linear Actuator/C120 LNBF...Ku-Band LOS from 30W-129W
Receivers: Toshiba TRX-1820 Analog-->AZBox Elite/Openbox S9 HDx2***GeosatPro microHD
OTA Digital: CM 4228/CM 7777 Preamp/Apex DT-250 for OTA Locals, Toshiba 46" Regza & Toshiba 19" LCDs
In Progress: (2) Birdview 8.5' (1 solid & 1 perf) w/Birdview H-H mounts, "Drake" 10' solid alum....*BVOC Asst. Cook & Bottlewasher*
06-03-2008 05:13 PM #4
Mounts just fine to a sg2100
BobGeoSat microHD: 1.2m dish mounted on SG 9120 motor
Dish 211K: Dish 1000.2@110,119,129 (Public Access/Interest channels and Dish Welcome package).
Bob Westcott
Click here if you have benefited from SatelliteGuys.us
06-03-2008 09:20 PM #5
My 3ABN dish was one of the earlier models and it would not fit on the SG2100 motor. I had to modify it. I had take the bracket that mounted to the pole off and I had to bolt the part that mounted to dish directly to the motor shaft. The elevation was way off from what it was supposed to be but I got it tracking th arch good.
06-04-2008 04:07 AM #6The newer 3ABN dishes are a perfect fit to the SG-2100.
ADVERTISING BOX
Current systems: 3X GEOSATpro microHD PVRs; Digitrans DTE-7150 DVB/Digicipher II; SiliconDust HDHomeRun ATSC/QAM networked tuners; fixed 1 meter Channel Master dish with Eagle Aspen P870 FSS stacked Ku LNB; 2X 3ABN 36" dishes with Sadoun KBSL1 stacked Ku LNBFs on Powermax SG-9120B H-H motors; fixed Sadoun SD180G 1.8 meter dish with Eagle Aspen B1SAT stacked C LNBF; Winegard Square Shooter OTA DTV antenna
Register To Reply
