Quantcast
Basic Cable, Dish Network, and OTA Antenna
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 5 of 5
  1. #1
    rockymtnhigh's Avatar
    rockymtnhigh is offline Just Ask for Help!
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Apr 14th, 2006
    Location
    Normal, IL
    Posts
    26,727
    Post Thanks / Like
    Ok, I have an OTA antenna, which I am using in conjunction with my Dish Network system. But I also have basic cable from comcast, which provides unencrypted HD QAM feeds.
    I want to be able to add the QAM feed to my primary HDTV. My thought was to see if I could diplex the coax run that currently is limited to the OTA antenna.
    Is that possible? Can I combine the comcast and OTA antenna using a diplexer, and then just split it out again at the tv, one going to Dish's Antenna IN, and the other going to the antenna in on the tv?
    Herding Cats since 2007.
    Dish: Vip722, 4.5 TB of External HDDs, Dish 1000.2, America 200 w/locals, Sony KDL-40XBR4 LCD, Apple TV, Toshiba HD A20 HD DVD, Sony BD player, Denon AVR 1310 Receiver, Infinity sound.
    HT Room: 106" Screen, Mitsi HC1500 720P projector, Dish vip722, Toshiba HD A2 HD DVD; Sony BDP-BX1 BD, Denon AVR788 7.1 receiver; Slingbox HD Pro.
    Other: iPad (3rd gen); iPhone 5; 13" core -i5 MacBook Air (2011 model), 13" core i7 Macbook pro (spring 2011), Dell W7 PC
    Follow me on twitter @rockymtnhigh , Email: rocky @ satelliteguys.us
  2. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! RandallA did! Help Support The Site And Get Rid of the Syndicated Ads, RandallA did! If you enjoy the site consider supporting it, RandallA did! Be COOL like RandallA and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 13th, 2004
    Location
    San Francisco Bay Area
    Posts
    10,302
    Post Thanks / Like
    "Is that possible? Can I combine the comcast and OTA antenna using a diplexer, and then just split it out again at the tv, one going to Dish's Antenna IN, and the other going to the antenna in on the tv?"
    No, it's not possible. A diplexer combines CATV/UHF/VHF and satellite signals. One way to do it is to combine OTA and CATV with a regular splitter and then combine those two with the satellite signal using the diplexer. At the other end you use another diplexer to split the signals and another splitter to split the OTA and CATV.
    The problem with that is that your antenna will be broadcasting the CATV channels and AFAI it's illegal to broadcast them. I would just run a second cable but others might have other suggestions like the Super Node or the use of notch filters.
  3. #3
    Proud Staff Member
    Join Date
    Apr 14th, 2006
    Location
    Normal, IL
    Posts
    26,727
    Post Thanks / Like
    Thread Starter
    Ah... wasn't thinking about it serving as a broadcasting of the signal; was just thinking it was a coax line that I could use.
    Obviously I could use that line if I was willing to disable the OTA channels, by disconnecting the antenna's coax, but that was not my goal. Just want to find a way to get the QAM feeds while leaving the Dish stuff alone.
  4. #4
    Join Date
    Nov 5th, 2007
    Location
    Las Vegas, NV
    Posts
    2,835
    Post Thanks / Like
    Quote Originally Posted by RandallA View Post
    This arrangement wouldn't create a broadcast of cable signals since they are flowing in the same direction as the OTA signals towards the box. Splitters usually have high RF Isolation between OUT ports so the cable signals wouldn't be flowing from the OUT port where they are being fed in to over to the OUT port where the OTA is being fed in to.
    I think his biggest problem with doing this would be the possibility of some OTA stations sharing the same frequencies as the QAM signals he's trying to receive.
  5. #5
    Proud Staff Member
    Join Date
    Apr 14th, 2006
    Location
    Normal, IL
    Posts
    26,727
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    My research has shown that I can't diplex OTA and basic cable; they use the same frequencies.
    I can diplex Dish and Basic Cable, BUT there is a chance I will have that overlap problem with the QAM feeds. I haven't taken the time to try it yet; primarily since to do the test I will need to pull the TV off the wall, and feed some coax up the wall; not hard, just haven't had time to try it yet.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
