Results 1 to 3 of 3
09-10-2004 11:01 AM #1
Good Off Air Analog and Digital Amp?
I have an attic antenna that I use for Analog off air, and for off air digital on the Dish 811. I normally watch off air SD on analog since it looks better than the SD off air digital on the 811. The HD off air looks great on the 811.
After recently running an RG6 run to my basement the signal from the antenna is now split to a total of three runs. The run heading to the Living room has a splitter with one leg going directly to my Sony HD RPTV and the other going to the 811. The 811 Satellite feed has its own run directly from the Dish. Although my analog signal still looks pretty good, I couldn't help wondering if it could be improved by putting an amp just off the antenna.
I picked up a Recoton 10db 50-900mhz amp at BB as it was the only thing I could find locally (one input, four outputs). Most of my analog channels now look slightly better except for one that was very weak already, it now has alot of lines running at angles through the picture.
Since this amp was a cheap one at $16 I'm wondering if a better amp would provide better signal quality. Since its in the attic it has to be able to handle the temperature extremes of a midwest climate up there.
If I should try a better amp, can someone reccomend a model/brand and a place to get it? What price range should I expect to pay and should I look for a particular DB amplification and frequency range?
Thanks.
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
09-10-2004 11:01 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Posts
- Many
09-10-2004 03:13 PM #2
Some possibilities include the Winegard DA-1118 (
http://www.winegard.com/offair/DA100..._etc_chart.htm
) and the Channel Master 3042/3043/3044/3045 (Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
http://www.channelmaster.com
You can buy them at either Warren Electronics (
http://www.warrenelectronics.com/
), or Stark Electronics (
http://www.starkelectronic.com/allmatv.htm
Cheap amps are easily overloaded by strong local TV and FM stations. My pick is the Winegard DA-1118. If your weak stations are only in the UHF band (channels 14-69), then go with the Winegard DA-405. It passes FM and VHF, but cannot be overloaded by VHF/FM.
09-10-2004 06:18 PM #3Also, if the amp has multiple outputs, you should use a 75ohm terminator on each unused output to prevent interference and signal loss.
ADVERTISING BOX
FYI:
-It's "couldn't care less", not "could care less".
-It's "would've", "should've", and "could've", not "would of", "should of", and "could of".
-It's "voila!", not "walla!" (That's right. You've been speaking French all this time.)
-The first word in each sentence should be capitalized.
-A period goes at the end of each sentence.
-Commas are also a good idea, on occasion.
Register To Reply
