Results 1 to 6 of 6
Thread: Skew? What is that?
  1. #1
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    Skew - Polarity
    When you set the skew (Polarity) on your LNBF you are lining up your dish exactly to the same horizontal/vertical position as the satellite in the sky. The satellites all lie in a curve in the sky ( Clarke Belt ) and so are at different heights. Ku satellites use Horizontal and Vertical liner polarization and so the skew has to match the (H/V) position of the satellite for optimum satellite signal strength/quality.
    When standing in front of your dish, rotate the LNBF anti-clockwise for
    + skew values.
    Rotate the LNBF clockwise for - skew values.
    When the LNBF is straight up and down it is in the zero position.
    Keep your LNBF in the zero position when using a motor mount.
    This info is relevant only for liner Ku band LNBF.
    Polarization is not a factor with circular (L/R) polarized DBS LNB.
    On a multi LNB DBS satellite dish (Phase III / Dish 500...) the reason the skew is set is to simply level or align the LNB'S with the satellites in the sky.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Aug 18th, 2004
    Location
    The Boilermaker State (#19)
    Posts
    3,840
    Post Thanks / Like
    Pete,
    I always thought skew was the same thing as polarity. When I hit the auto skew isn't is spinning the little hook around inside the feed horn for horizontal or vertical? Set me straight, I would hate to think I have been wrong for 20 years.
    ~J~
    ~J~ ~Deke Leonard~
    PROUD NEW YORK YANKEE FAN SINCE 1960
    8 ft Spun Aluminum Dish since 1983
    Motorola 922, Traxis 3500, 6000HD, AZ Box Primium Plus, Quali TV
    C & Ku Band-Digital, Analog and DVB S, S2-4:2:0, 4:2:2, HD
    UNITED STATES AIR FORCE 1970-1974
    3708 BMTS, FLT 1462 (ATC), Lackland AFB, TX
    351st Security Police Squadron (SAC), Whiteman AFB, MO
    4683rd Security Police Group (ADC), Thule AB, Greenland
    INDIANA AIR NATIONAL GUARD 1982-1984
    181st Civil Engineers, Prime Beef, Hulman Field, IN
    DAV
    ~41 CONSECUTIVE INDIANAPOLIS 500s AND COUNTING~
  4. #3
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    Thread Starter
    With C band systems yes, but with a smaller fixed dish the LNB is rotated by hand to the correct skew/polarity then clamped in position, with a KU motorised dish the LNB is set in the zero position and the dish sets its own skew as it turns and tilts, another great reason to have a motorized dish. As someone pointed out the other day they are getting a motorised system not just for the FTA channels but its a great way to keep up to date with whats going on with EVERY satellite up there!
  5. #4
    Join Date
    May 20th, 2004
    Location
    Manhattan, KS
    Posts
    692
    Post Thanks / Like
    Peter,
    I should have a PCI DVB card this week (because it was cheap) and I am going to see if WGN-DT is still in the clear on Nimiq 2 at 82 degrees. According to a site I went to to help point my old Dish net dish(DBS, single lnb), it says the skew is -17.11 Do I really have to do that? I am thinking no based on your first post here.
  6. #5
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    Thread Starter
    No need to bother with skew on a DBS satellite, straight up and down will work for the DBS LNB, same as DirecTV single dish.
    I find even a DBS signal gets stronger when the dish is on a motor mount as the dish tilts as it swings and collects slightly more signal.
  7. #6
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    Thread Starter
    Sadouns Installation page about SKEW.........
    http://www.sadoun.com/Sat/Installati...stallation.htm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
