Results 1 to 5 of 5
Thread: Problem with Dish 311
  1. #1
    Join Date
    Oct 29th, 2008
    Posts
    Post Thanks / Like
    Hello, I'm having problems installing my new Dish 311.
    Here's the deal: My old receiver broke, so I got them to send me a new one. When I plug it in and connect everything, it won't pick up a signal. I run the check switch and it says X on everything. Also, it makes a very low whining noise and gets quite warm on top. My old one used to do this, too... but I'd unscrew the coaxial cable and it'd quit.
    I'm pretty sure it's not the coaxial, but can it be anything else?
    Thanks in advance,
    Mike
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Nov 16th, 2005
    Location
    Salt Lake City, Utah, United States
    Posts
    883
    Post Thanks / Like
    You have a short on the cabling somewhere. Check to make sure the connector doesnt have any braiding from the jacket touching the center. If they both did it then its a pretty sure sign something is amiss with your cabling/lnbs.
    _____________________________________________________________
    "Yes yes you like distant signal, very good I get you that sir" - Chris Walker 11/30/06 - Priceless Quote....
    Dish Network - The leader in HD BS
  4. #3
    Join Date
    Jan 10th, 2008
    Location
    Central Vermont
    Posts
    223
    Post Thanks / Like
    First, are there any other receivers in your system and (if there are) are they working properly? If you are getting X when you run the check switch the receiver is somehow not receiving any satellites. Did your previous receiver have the same problem? In trying to troubleshoot your system you need to look over everything. Start at the receiver and check the cable. Follow the cable out to the dish looking for any signs of breakage or other problems. If there are any connections, check those as well. Lastly, the dish could be out of alignment. Have you have any recent high winds or other severe weather? If the dish moved even an inch, you lose your satellites and it will still look as if is it pointed correctly. It could be that your installer never tightened all the bolts on the dish to withstand high winds. With your 311 showing X, I suspect that something else in the system is the cause. It has been my experience that receivers are usually not the problem. Hope this helps!
  5. #4
    Join Date
    Oct 29th, 2008
    Posts
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by WiCkeDuDe View Post
    That little piece of braiding caused all this. Thanks for the help
    Thank you too, kb2vgp. I do have two receivers and the other works fine.
  6. #5
    Join Date
    Nov 16th, 2005
    Location
    Posts
    883
    Post Thanks / Like
    No problem. Ive seen it many times.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
