Results 1 to 5 of 5
Thread: Direct tv receiver and remote problem.
  1. #1
    Join Date
    Nov 18th, 2008
    Posts
    6
    Post Thanks / Like
    Smile Direct tv receiver and remote problem.
    We just got a new R15 300 receiver(the 1st one was bad),the problem is this: when you select #'s on remote, it doubles up, say you hit 2, before you can do anything else there are already three 2's on the screen. Sometimes it doesn't even take the command you are giving. We called DTV and quibbled for over an hour and they finally sent us a new remote(RC64) but it does the same thing. I am thinking the problem is the receiver, as we have another remote borrowed and it does same thing. Does anyone have this problem, or can you help out?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Oct 22nd, 2004
    Location
    Binghamton, NY
    Posts
    4,014
    Post Thanks / Like
    This could be a case of IR interference. Remove any other remotes from the room and see what happens. Another check is to use the remote up close to the unit and see if the problem remains.
    HR23-700, HR24-500/AM21, Samsung UN46C6500
  4. #3
    Join Date
    Nov 18th, 2008
    Posts
    6
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by jdspencer View Post
    I am only using one remote. Doesn't help up close. What do you mean by IR interference?
  5. #4
    Join Date
    May 3rd, 2007
    Location
    Wayne County,Pa
    Posts
    12,070
    Post Thanks / Like
    Gamer IDs
    PSN ID: damon-77_
    Sometimes that happends to me ,but mostly because its not very responsive and I end up getting inpatient and keep hitting the button. Most likly a receiver issue. The R16 are slow to respond. Maybe yours is just worse then most. Call D* and have a tech look at it.
  6. #5
    Join Date
    Oct 22nd, 2004
    Location
    Binghamton, NY
    Posts
    4,014
    Post Thanks / Like
    IR interference is when an outside IR source interferes with the operation of the remote. Another remote, used by another device, with a stuck button can cause this. With interference, pressing a button such as '2', is received by the receiver, but the interference keeps the receiver from seeing that the remote IR signal has been removed and such just repeats. When you try up close, your body can block the outside source and then it would work.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
