Quantcast
119 missing from configuration
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 5 of 5
  1. #1
    Join Date
    Nov 26th, 2008
    Posts
    13
    Post Thanks / Like
    Last night my dish 625 was having problems and kept losing the signal. I called up the great Dish Network support and they walked through the usual useless steps.
    However when we ran the switch check, an error displayed there was a problem with one of the satelittes, do you want to remove it from your configuration. The lady told me to select yes. I tried asking if she was sure and she said to do that.
    Needless to say, the dish found the signal and the picture came on. But I am missing a lot of channels. It looks like 119 got removed from the configuration and doesn't even show up the check switch screen anymore. Of course she couldn't help me any further and it's going to be a week and a half before a technician can get here.
    Anybody have any ideas how to get 119 to appear again ???
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Jun 22nd, 2008
    Location
    OR
    Posts
    626
    Post Thanks / Like
    A week and a half? Where are you?
    Try pulling the plug for about 30 seconds and running the check switch test.
  4. #3
    Join Date
    Nov 26th, 2008
    Posts
    13
    Post Thanks / Like
    Thread Starter
    Done That
    I have unplugged it and everything else under the sun. Since the Customer Service lady had me select save on the screen it saved the configuration with 119 no there anymore.
    Is there anyway to get the box to see 119 again ?
  5. #4
    Join Date
    Feb 14th, 2004
    Location
    Dayton OH
    Posts
    10,002
    Post Thanks / Like
    Remove the satellite input(s) and run a "Check Switch". It will take longer than usual with the cables pulled. Let it finish.... This will "clear" the check-switch matrix. Power off the receiver (pull the electric power from the wall outlet), connect the cables, and turn the receiver back on. If it doesn't automatically go to the "Point Dish" screen, go there manually and do a "Check Switch" again and see if it finds the satellites this time.
  6. #5
    Join Date
    Nov 26th, 2008
    Posts
    13
    Post Thanks / Like
    Thread Starter
    Fixed
    ADVERTISING BOX
    Hall,
    That worked !!!!!!
    Thanks !!!!!!!!!!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
