Results 1 to 6 of 6
Thread: Extending UHF range of remote control?
  1. #1
    Join Date
    Dec 29th, 2004
    Posts
    106
    Post Thanks / Like
    Hi,
    I have my 722 mounted in the basement and TV 2 is up a floor. I guess its mounted in a poor location because the range is really poor despite fresh batteries and the antenna hooked up properly. I was wondering if I could use some RG6 to essentially extend the antenna. This way I can mount the antenna on the same floor as TV 2 and I'm hoping it should resolve my issues.
    Any ideas?
    Thanks,
    Joe
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! boba did! Help Support The Site And Get Rid of the Syndicated Ads, boba did! If you enjoy the site consider supporting it, boba did! Be COOL like boba and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 12th, 2003
    Location
    Dorchester, TX.
    Posts
    9,056
    Post Thanks / Like
    Frequently adding a 6' length of cable to the receiver UHF antenna connection then a F-81(double female splice) allows mounting near ceiling level. This usually extends reception range.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! lakebum431 did! Help Support The Site And Get Rid of the Syndicated Ads, lakebum431 did! If you enjoy the site consider supporting it, lakebum431 did! Be COOL like lakebum431 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 5th, 2005
    Location
    Norris, TN
    Posts
    10,362
    Post Thanks / Like
  5. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Stargazer did! Help Support The Site And Get Rid of the Syndicated Ads, Stargazer did! If you enjoy the site consider supporting it, Stargazer did! Be COOL like Stargazer and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 7th, 2003
    Location
    Western WV
    Posts
    15,176
    Post Thanks / Like
    Use splitters at both tv's (one tv is where the receiver is at and the other tv is where your trying to change channels from). There are two sides of the splitter, one side has one end and the other side has two ends.
    On the one tv where the receiver is you put the one side of the splitter with one connector on the coax. The other side of the splitter has two connectors, one going to the UHF antenna port and the other to a UHF antenna itself.
    On the other tv where you want to channels from, the one side of the splitter with one connector is connected to the coax wire coming from the receiver. The other side of the splitter has two connectors, one goes to the tv2 output on the back of the receiver and the other goes to a UHF antenna output on the back of the receiver. If you still have other rooms that you use TV2 on then you will need a four way splitter that has one input and three outputs and need to connect the additional output to a UHF antenna.
  6. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! KAB did! Help Support The Site And Get Rid of the Syndicated Ads, KAB did! If you enjoy the site consider supporting it, KAB did! Be COOL like KAB and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 20th, 2005
    Location
    Indy
    Posts
    14,482
    Post Thanks / Like
  7. #6
    Join Date
    Nov 19th, 2008
    Location
    midwest
    Posts
    41
    Post Thanks / Like
    bah humbug before you try any of that.....try the attenuator it should be in the box.... little silver piece that screws on before your antenna does, sometimes houses have alot of astray frequencies that can mess with your remote....let me know if im right.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
