Page 1 of 2 12 LastLast
Results 1 to 6 of 9
Thread: IR/UHF Pro 4.0 Remote Programming?
  1. #1
    Join Date
    Mar 10th, 2009
    Location
    PA
    Posts
    Post Thanks / Like
    how do i get the remote to work with my Hitachi TV? I don't have the user guide or anything...
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Mar 6th, 2009
    Location
    Carrollton Ga
    Posts
    38
    Post Thanks / Like
    Quote Originally Posted by SuperHumanly View Post
    1. manually turn on the tv
    2.press and hold the tv button until all the lights flash red, then release the tv button, the tv button should now be steadly blinking red...
    3.press the power button and release it. now the tv button should be solid red...
    4.now slowly press the down button repeatedly (SLOWLY!!! (allow 2 seconds between pushes)) until the tv turns off.
    5. press the pound button
    should be good to go... let me know
  4. #3
    Join Date
    Mar 10th, 2009
    Location
    PA
    Posts
    Post Thanks / Like
    Thread Starter
    Just tried that, hit the button quite a few times with no results, one of the times the "SLEEP TIMER" thing popped up, but the TV never powered off. I tried again and locked the code onto the one that made the SLEEPT TIMER pop up, but none of the other keys did a single thing.
    I stopped hitting the down arrow when the lights started blinking about 4-5 times in a row after hitting down.
    TV is no more than 2ft in front of me, with a direct line towards the remote sensor. New batteries in the IRUHF Pro, also.
    Edit: I also found this PDF guide, which lists the remote codes for all brands -- strangely enough, NONE of the Hitachi codes worked.
    http://www.dishnetwork.com/downloads...te_Control.pdf
  5. #4
    Join Date
    Mar 6th, 2009
    Location
    Carrollton Ga
    Posts
    38
    Post Thanks / Like
    Okay... try theses codes...
    523, 526, 548, 549, 553, 554, 555, 585, 597, 626, 636, 638, 643, 648, 652, 654, 655, 665, 688, 669, 670, 672, 673, 702, 718, 726
    press and hold the tv button just as before, except now after the buttons all light up, enter theses codes one at a time and press pound after each one and try to turn the tv on and off...
  6. #5
    Join Date
    Mar 6th, 2009
    Location
    Carrollton Ga
    Posts
    38
    Post Thanks / Like
    by the way DO NOT hit the power button after holding the tv button this time...
  7. #6
    Join Date
    Mar 10th, 2009
    Location
    PA
    Posts
    Post Thanks / Like
    Thread Starter
    Nope. tried all those codes and the TV didn't turn off...
    Although, with the 674, the Volume, Mute & Channel Up/Down buttons did work, but not power, or any numbers.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
