Quantcast
Will I be able to receive 123W
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 9
  1. #1
    Join Date
    Mar 29th, 2009
    Location
    northeast
    Posts
    Post Thanks / Like
    I am a previous subscriber to Dish Network. Will I be able to receive 123W on that dish? It's about 24" x 31" oval. I'm hoping I can leave the dish aimed where it's at (pointing toward 119W), buy a linear LNB and FTA receiver and be good to go. Will this work? Thanks.
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Dec 1st, 2006
    Posts
    1,516
    Post Thanks / Like
    Quote Originally Posted by SVB View Post
    the dish is marginal size - 31" may see some interference from Echostar 9 at 121 deg W or the strong AMC-21 at 125 deg W.
    you can buy a LNBF, a FTA receiver and you'll have to probably homebrew a bracket for the LNBF and you'll have to repoint the dish to 123 deg W.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! DJ Rob did! Help Support The Site And Get Rid of the Syndicated Ads, DJ Rob did! If you enjoy the site consider supporting it, DJ Rob did! Be COOL like DJ Rob and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 8th, 2003
    Location
    Denver, Colorado
    Posts
    1,563
    Post Thanks / Like
    If it's only 24" high, I don't think it will work. You need at least a 76cm. A 90 cm is better because of the 2 degree spacing.
  5. #4
    Join Date
    Dec 1st, 2006
    Posts
    1,516
    Post Thanks / Like
    Quote Originally Posted by DJ Rob View Post
    yep, I forgot about the 24 inch dimension. Stuff is cheap enough you could try it, I guess, but I have to concur results may not be good.
    120cm is great for 2 deg spacing - my 90cm was so-so, my 120cm is solid for separating 2-deg spaced sats like G18 and AMC-21.
  6. #5
    Join Date
    May 6th, 2005
    Location
    Metro New Orleans, LA
    Posts
    6,269
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Generally speaking, a Superdish (this is what I think the OP has) will work marginally for FTA. There is a Ku stacked LNB, so no need to replace that.
    123w, however, may not be the best target for that undersized dish. There is potential interference from 125w next door that could cause trouble. As stated above, a 90CM dish is recommended on that satellite.
    Current systems: 3X GEOSATpro microHD PVRs; Digitrans DTE-7150 DVB/Digicipher II; SiliconDust HDHomeRun ATSC/QAM networked tuners; fixed 1 meter Channel Master dish with Eagle Aspen P870 FSS stacked Ku LNB; 2X 3ABN 36" dishes with Sadoun KBSL1 stacked Ku LNBFs on Powermax SG-9120B H-H motors; fixed Sadoun SD180G 1.8 meter dish with Eagle Aspen B1SAT stacked C LNBF; Winegard Square Shooter OTA DTV antenna
  7. #6
    Join Date
    Sep 22nd, 2005
    Location
    L.A., Calif.
    Posts
    10,623
    Post Thanks / Like
    ADVERTISING BOX
    I'm with Tron. -
    Few additional comments:
    - you'll have to slightly re-aim your dish, but since you're a former subscriber that should not be a problem.
    - no purchase required of an LNB if you do have a SuperDish. But, let's get that clarified.
    - I believe it's the 31" wide that'll bite you in the butt, not the 24" height.
    - You should get -some- transponders on 123°, but probably not all (just a guess)
    - do you need brand suggestions on a receiver? Blind scan is highly desirable. Don't get a hacker-box.
    edit: oh, you're in the north east? that'll make the 123° & 125° satellites appear even closer together to you.
    Really not the best situation. However, tell us more about your dish, and give a try.
    Straight Talk on AT&T iPhone 4, iOS 5.0.1, BB 3.10.01.
    Retired Apple iPhone 3GS, iOS 5.0.1, BB 6.15.00.
    I repaired smashed screen & more on both.
    : BirdView 8½' solid & GBox V3000.
    AMCI 8' perf (maybe a DH?) & AJAK-180.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
