Results 1 to 5 of 5
Thread: Dish DVR and local channels from antenna
  1. #1
    Join Date
    May 7th, 2009
    Location
    Colorado
    Posts
    Post Thanks / Like
    I have Dish Network and receive my local channels from an external antenna instead of paying them for local channels. I just hooked up a second TV and with TV2 I cannot scan for local channels. Dish tells me that I cannot get the local channels from an antenna on the second TV. Is there a way I can work around this?
    Thank You
    Tim
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Oct 26th, 2006
    Location
    Cincinnati, Ohio
    Posts
    206
    Post Thanks / Like
    If its not a 222k or 722k with and over the air module, then no. Those are the only receivers that allow over the air viewing on tv2. Your only other option, if you did not want to replace your receiver with a K series, is to us the tuner in your tv.
  4. #3
    digiblur's Avatar
    digiblur is offline Proud Staff Member
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Jun 8th, 2005
    Location
    Louisiana
    Posts
    14,207
    Post Thanks / Like
    There is a trick. Go to TV1 and pick the OTA channel and hit record. Go to TV2 and hit play on that recording. Kind of a pain but it works if you do not have the 722k.
  5. #4
    Join Date
    Sep 29th, 2005
    Location
    Greentown, Pennsylvania, United States
    Posts
    7,392
    Post Thanks / Like
    Get a digital tuner box and connect it to the second tv, all you need to do is split the ota signal before receiver and combine that signal with the rf out to the second tv. You then add the converter box at before input into second tv.
  6. #5
    Join Date
    Sep 3rd, 2008
    Location
    New Jersey
    Posts
    302
    Post Thanks / Like
    The other thing you can do is run the receiver in single mode.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
