Results 1 to 6 of 16
Thread: geniatech dvb-s
06-06-2009 01:03 PM #1
geniatech dvb-s
where are the linux driver for this card
geniatech digistar dvb-s
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
06-06-2009 01:03 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
06-07-2009 05:27 AM #2
As far as I am aware there is no need for a driver unless you are talking about a specific application. I have one of these cards and it works fine with Kaffeine provided you have a kernel that contains the support for the card. The support has been in the kernel for some time so unless your kernel is really old likely you have it.
With the card in the box try
# dmesg | grep DVB
This should show whether your card was seen on boot up
and what the kernel was able to do with it.
06-08-2009 12:25 AM #3
SatelliteGuys Regular
- Join Date
- Jun 6th, 2009
- Location
- los angeles
- Posts
- 80
- Post Thanks / Like
- Thread Starter
mythtv
im using myth tv
i can only fine kaffeine player when installing kaffeine from
source, its some like sudo apt-get update install
then, it is somethin like sudo apt-get kaffeine
but it just simply installs a player for music
well on # dmesg | grep dvb
i get.......nothing like it just goes to same line
but when i type in
root@xxxx-desktop:/home/xxxx# dsmeg | grep video
[ 3.701676] pci 0000:00:0f.0: Boot video device
and thats all
can you help me see if i did something from ubuntu 9.04
other that that i will try a desktop not a server
you think it has to do something with bios and how its setup with ubuntu
im using vmware workstation 6.5.2 build-156.735
i had the same problem even when installing ubuntu on it self without any othe operating sytem
other that ubuntu 9.04. and did the same thing didn't read on boot i guess like you were trying to tell me if it woul read from the beginning
so im just going to try a desktop, other that that we can try to fix it
also at esc at boot says the following
ubuntu 9.04, kenel 1.26.28-11-geneicLast edited by batzzz19; 06-08-2009 at 12:33 AM. Reason: fixing it
06-08-2009 05:44 AM #4
Genaitech Digistar 103G support was added in kernel 2.6.18 in Sept of 2006. It looks like you need to upgrade your kernel. There are lots of sites that try to help you upgrade the kernel, one place to start is
Upgrade Linux kernel
.Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
06-08-2009 09:41 PM #5
- Join Date
- Jun 6th, 2009
- Location
- los angeles
- Posts
- 80
- Thread Starter
i didn't get far
how do i install redahat as im using x32bit
and server instel xeon motherboard
how do i do this.????????/
06-08-2009 10:26 PM #6
- Join Date
- Jun 6th, 2009
- Location
- los angeles
- Posts
- 80
- Thread Starter
do you think
i need 8.04 with latest kernel or get jaunty 9.04 with latest kernel
ADVERTISING BOX
which one should i install
Register To Reply
