Quantcast
722 & Cable
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 3 123 LastLast
Results 1 to 6 of 13
Thread: 722 & Cable
  1. #1
    Join Date
    Jul 20th, 2009
    Location
    united states
    Posts
    7
    Post Thanks / Like
    722 & Cable
    The vip 722 has an antenna input and a setup screen where you can select the type input you have (over the air, irc, hrc, or cable). When I plug in the tw cable tv coax and run a channel scan, no channels are found. It works fine with an over the air antenna; but I want to use the 722 box to watch cable so that I can use the dvr function. What do I need to do to get cable to work thru the 722 ird.
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Jim S. did! Help Support The Site And Get Rid of the Syndicated Ads, Jim S. did! If you enjoy the site consider supporting it, Jim S. did! Be COOL like Jim S. and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 2nd, 2006
    Location
    upper Northumberland County, PA
    Posts
    3,664
    Post Thanks / Like
    It doesn't do QAM. Nobody knows why the "cable" option is there, since cable systems that do 8VSB are almost unheard-of. (It should've been a requirement, IMO.) Some people will try to say that that's the setting for the output format, but I'm pretty sure that that's on another menu somewhere.
    Dish 1000.4 Eastern Arc dish, ViP 622 with broken HDMI port, Onkyo 606 receiver, Samsung 46" LCD
    GeoSatPro 90cm dish, Sadoun PowerTech DG-280 motor, DMS Avenger PLL321S-2 LNBF, Amiko Alien 2 receiver
  4. #3
    Join Date
    Sep 29th, 2005
    Location
    Greentown, Pennsylvania, United States
    Posts
    7,174
    Post Thanks / Like
    The cable option is there if you want to combine the receiver's output with local cable to run to other tv's through out the home.
  5. #4
    Join Date
    Jul 20th, 2009
    Location
    united states
    Posts
    7
    Post Thanks / Like
    Thread Starter
    If it's and output port, why doesn't the scan pick up the cable channels?
  6. #5
    Join Date
    Dec 12th, 2006
    Location
    Central IL/SW FL/Big Island
    Posts
    2,997
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Quote Originally Posted by bouser View Post
    The "Cable" option outputs the receiver's TV2 output to TV2 on an analog cable frequency instead of an OTA frequency. The ViP receivers themselves only have ATSC tuners for OTA reception. They do not have clear QAM tuners needed for cable nor cablecards for encrypted QAM on cable.
  7. #6
    Join Date
    Jul 20th, 2009
    Location
    united states
    Posts
    7
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    That's what I'm getting at. Can anything be done to the cable signal ( like a cable box ) to convert QAM to ATSC for input into the tv input port on the 722?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
