Results 1 to 6 of 8
08-18-2009 04:24 PM #1
HDMI V1.3 Extenders over Single CAT5/6/7
Source -- Atlona Press Release :Atlona Technologies officially releases new HDMI V1.3 Extenders over Single CAT5/6/7 up to 200ft, the AT-HD-V40SRS
Atlona Technologies, a solutions based manufacturer of Audio Video accessories, has released their new HDMI V1.3 Extenders over Single CAT/5/6/7 up to 200ft, the AT-HD-V40SRS
Atlona Technologies, solutions based manufacturer of Audio Video accessories, has officially released their newest HDMI V1.3 Extenders over single CAT5/6/7. This new and updated unit is designed to replace the existing AT-HDMI40SRS due to the addition of HDMI1.3 as well as other capabilities. This Atlona HDMI1.3 extender is the perfect solution for those who need to extend an HDMI1.3 signal long distances over low-cost single CAT5/6/7cable. The AT-HD-V40SRS Extenders can boost signal transmission in perfect video quality at lengths up to 110ft at 1080p, and up to 200ft at 1080i while supporting 7.1 Ch. audio. Compared to extreme lengths of HDMI, the extenders will help extend the length with no signal degradation. While the signal will send optimal Audio and Video quality, it is recommended to use shielded cat5/6 wire to get the best quality signal.
The AT-HD-V40SRS includes one transmitting unit and receiving unit. The transmitting unit is used to capture the input HDMI/DVI signals and carry the signals through one RJ-45 connector into one CAT5/6/7 cable. The receiving unit equalizes the sent multimedia data. With the equalization control switch on the receiving unit, users can adjust the equalization and have the ability to optimize the transmission distance between desired source and display. The installation of the this HDMI1.3 extender is quick and easy, no matter the technical expertise; simply place Sender unit next to your HD source such as, (HD-DVD player, Blu Ray player, Set-top-box, etc.) and place the Receiver unit next to your display and connecting a single CAT5/6/7 between the two. Along with being HDCP compliant, this unit is embedded with state of the art Silicon Image Chip-Set, allowing 99.99% compatibility with all other Audio Video equipment.
With Atlona’s AT-HD-V40SRS HDMI1.3 over single CAT5/6/7 Extenders, users can readily extend High Definition sources to any remote display through reliable and economic CAT5/6/7 cables. This cost effective solution is perfect for all home theater and business to business installations as well as any digital signage application.
Atlona’s AT-HD-V40SRS is currently available with an MSRP of $329.00
Atlona Technologies
Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
2013 SatelliteGuys at CES
dfergie@SatelliteGuys.US
For Breaking Satellite Industry News, Please Click Here
08-18-2009 04:24 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
08-18-2009 06:14 PM #2
Ouch... I'll just fish a long HDMI cable to bedroom when it gets to that point.
08-18-2009 06:43 PM #3
My father-in law has this in his new man "cave" he built in his house. I haven't seen it in action yet, but I will this weekend.
08-19-2009 12:19 AM #4
For that price, I will run my own wire just for HD. The only way I see this as a money saver is if the wiring would be hard to run and if cat5 was already there especially in hotels or if someone had money to burn.
08-19-2009 11:14 AM #5
I use cat5 HDMI converters. They have worked without issues. The main use is for runs that are too long/hard for HDMI. I have one run that goes outside, outside direct burial cat5e is available, HDMI is not.
08-19-2009 04:20 PM #6Is it cheaper to use a converter in some cases than running new HDMI wire or wire that can be used for HDMI? Can one not use another type of wire and put HDMI connectors on the ends?
ADVERTISING BOX
Register To Reply
