Quantcast
Best way to slave a PC DVB to two DVB receivers?
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 7
  1. #1
    Join Date
    May 12th, 2008
    Posts
    534
    Post Thanks / Like
    Hi all, I'm finally getting some real success with my Sky Star 2 PC DVB and want to slave it to both of my DVB receivers. The goal is to use the DVB receivers to blind scan and find 4:2:2 and HD mpeg2 feeds then enter the info into ProgDVB on the HTPC and watch them. What I have been doing is connecting a short section of coax from the PC DVB card to the loop out connector on one receiver at a time. This works ok but I'm tried of moving the cable from one DVB receiver to the other. This morning I tried a splitter that has DC power pass on one side and found one of the receivers (the one hooked up to the DC pass) had to be completly turned off by using the power switch on the back in order to use the other receiver.
    It would be nice to simply use the remote to turn off one of the DVB receivers.
    What do I need here? A splitter with no DC power pass on either side?
    Any other hook up I should try?
    Thanks, DC
  2. #2
    Join Date
    Sep 3rd, 2004
    Location
    Roseville, CA
    Posts
    5,817
    Post Thanks / Like
    You need a
    Dual output LNBF
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    with
    Multi-switch
    or
    a
    Bandstacked LNBF
    with a high frequency splitter (single port power passing suggested) such as Sadoun's new LNBF.
    Satellite AV, LLC (Gold Sponsor)
    Equipment Development / Distribution / Repair / Call Center
    888-483-4673 - http://www.satelliteav.com
    eBay Special Deals
    Attention Installers: Want more work? Join the Largest Satellite Technician Referral Website - www.FTAinstall.com
  3. #3
    Join Date
    May 12th, 2008
    Posts
    534
    Post Thanks / Like
    Thread Starter
    Hi, looks like I need to add some more info on my setup. Receiver 1 is a Mercury II hooked up to a signal 80 CM Ku dish with a motor. The dual LNB would work on it if I ran a second coax but I would prefer to use just one coax if I can.
    Receiver 2 is much more complicated, it is hooked up to my BUD and two Ku dishes with a DiSEqC switch between the three dishes and the dishes are not close together. It would take a lot of work to run all the extra cables.
    The PC DVB card will only be used to view 4:2:2 and HD that I can not receive on the DVB receivers. It will not be used to view something else at the same time. Another words the DVB receivers are used to control the motor and DiSEqC switch and power the LNB.
    The PC DVB card only has to receive the RF. I think all I need is a signal splitter but I have not done a hookup like this before so I'm not sure.
    How do some of you guys that have mutiple receivers hook them up?
    Thanks, DC
  4. #4
    Join Date
    Sep 22nd, 2005
    Location
    L.A., Calif.
    Posts
    10,817
    Post Thanks / Like
    brainstorming:
    Just for the purposes of brainstorming, let me suggest a hookup.
    I'm sure with member feedback, we can eventually come up with a working solution.
    What about a diseqc switch... or, maybe a 22khz switch?
    You use it to hook your PCI card to the two sources you want to monitor.
    I'd try DC Blocks (not much more than low value capacitor in a coax feedthrough) between the switch and the DVB receivers.
    I think that is the optimum configuration.
    The low value capacitors shouldn't pass the 22khz tone or diseqc commands up stream to the LNBs or other switches, so there's a reasonable probabliity this could work.
    Anyone find a flaw in that? Got a better idea? Different switch?
    Maybe something with a remote control? -
    Straight Talk on AT&T iPhone 4, iOS 5.0.1, BB 3.10.01.
    : BirdView 8½' solid & GBox V3000.
    AMCI 8' perf (maybe a DH?) & AJAK-180.
  5. #5
    Join Date
    Sep 3rd, 2004
    Location
    Roseville, CA
    Posts
    5,817
    Post Thanks / Like
    The closest that I would suggest for your application is a Multi-Switch that accepts 10 inputs and outputs to 3 receivers. Since that does not appear to exist, check out the Spaun
    SMK13089F - 12 SAT Inputs / 1 Terrestrial / 8 outputs / IF Loop Through
    . This would take two outputs from each source and make them available for each receiver. Each receiver would need to support DiSEqC 1.1 protocol. Total overkill in my opinion, but it is what it is!
    Second suggested way of doing this is to replace the LNBFs on the 4 KU band dishes with Bandstacking LNBFs then you would only need a Multi-Switch facilitating 6 inputs and 3 outputs. Since that does not appear to exist, check out the
    EMP-Centauri 9x4
    DiSEqc 8 SAT Inputs / 1 Terrestrial Input / 4 Receiver outputs.
    Probably most simple to connect the PC tuner to a DiSEcQ switch and select the IF looped output of one of the receivers. The selected STB will select the satellite and polarity. Use the PC card to only select the DiSEqC port and tune the signal.
    Last edited by SatelliteAV; 10-25-2009 at 02:58 PM. Reason: Anole beat me to the post, but similar suggestion!
    eBay Special Deals
  6. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! madmadworld did! Help Support The Site And Get Rid of the Syndicated Ads, madmadworld did! If you enjoy the site consider supporting it, madmadworld did! Be COOL like madmadworld and Click a Star and become a Supporting Pub Member today!
    Join Date
    Apr 7th, 2006
    Location
    up on the roof in SinCity
    Posts
    1,444
    Post Thanks / Like
    ADVERTISING BOX
    how about a simple a/b switch ? with remote
    ARCHER REMOTE-CONTROL VIDEO A-B SWITCH - eBay (item 290361902003 end time Oct-27-09 14:01:25 PDT)
    System
    C-band>13'BV/DH perf ,4-10'KTI 2 w/Ajak h-h,3-10'Wineguard 1 w/Ajak h-h , 7.5' KTI w/ Ajak h-h,7.5 Star Trak,8'Echostar, 7.5 Wineguard,
    Drake's 1824,1724,1624,GI-922,GI-920,Toshiba's 1520, 2220,GI 350,NextWave500,Prosat 390,Manhattan450
    KU>5)Fortec 36"90 cm, 6) STAB 100 & 120 Motors 1) Fortec 31"80 cm @97°, 5 1meter Fortec's,2 90 cm WSI's,1)World dish,1) Wineguard 1 meter,1)1.2meter unstamped @125.
    Pansat's 2800,3500,9000HD,7>9200 S-2 HD,TC-1000,9500HDX, Coolsat 8100,SV-8000 HD,Visionsat IV-200,,
    Vantage HD1100S.Azbox Ultra & Premium Plus,. 7 OpenBox S9's
    HTPC=.Prof 7301,Hauppauge Colossus
    DIRECTV 3)HR20-100S's,HR23-700 For 3D,ChoiceX,NBA L Pass,Sports Pack,NFL ST,NHL CI
    the most important reading you might ever do.
    http://www.resurrectionism.com/drgenescott.html
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
