Results 1 to 6 of 13
Thread: AMC9 Signal
11-03-2009 08:50 PM #1
AMC9 Signal
I am using a conaxsat nano box wih a 36inch , Ku LNBF. I have 170 feet of rg6 running back to the house. I have a S80-85/ Q35-40. Not good enough to watch RTN Network. Need some ideas. I can take the small tv out to the dish and have the same S/Q as in the house!
Should I upgrade the dish to a 1.2?
Should I buy a better Ku LNBF?
If I go to a 1.2 dish, then I could go to C-Band and Ku-Band?
Maybe use a inline cable amp?
I if you have not much money to spend, I start with cheaper items first!
Is there other RTN prgraming on C-Band?
Or just sit and wait an see.
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
Ku-Band, Openbox S-10, Dish: Ws-9036 90cm (36inch), H-H Motor: SG-9120, GEOSATpro SL1 PLL Standard Ku
Ku-Band, MicroHD, Dish: Ws-9036 90cm (36inch), Stationary (125W), GEOSATpro SL1 PLL Standard Ku
C-Band, MicroHD, 7.5 ft. UniMesh Dish, VonWeise Actuator V76-5, Gbox V3000, GEOSATpro C2 Dual LNB
11-03-2009 08:50 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
11-03-2009 09:40 PM #2
Honestly try and tweak the signal. But to answer the other options
1. if you want. But shipping is a bugger
2. what do you have right now for one?
3. you could but KU will suck if you use a C/KU LNB
4. no. The fact you get the same signal at 170 feet and 10 feet proves an amp is not needed
There are some RTV feeds on C-Band yes. Couple on G17 (91W)Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
All FTA stuff in storage right now
11-03-2009 09:58 PM #3
- Join Date
- Oct 17th, 2009
- Location
- North Central Indiana
- Posts
- 296
- Post Thanks / Like
- Thread Starter
11-03-2009 09:59 PM #4
I use a 30" in Minnesota and have decent numbers....not stellar but stable numbers
11-03-2009 10:19 PM #5
keystone what are you getting on the other tps on that satellite? There's some color bars that should just about max out your receiver, what kind of signal/quality do you get there? 11775Horizontal 4232 bars, scans in as AMC9/3F...
Curious that you get exactly the same signal # at the dish and after 170' of cable.Icon 550, Vantage 1100HD (thanks Stogie) on .90M primestar DG380 motor.10'Sami+GI650 for c-band.
CS5000 now on 1m primestar-polar mount backup system.
Avatar: Bengal tiger. Think you have a real kitty?
11-04-2009 06:16 AM #6Keystone
ADVERTISING BOX
Where in Northern Indiana are you? It might be less expensive to take a couple of hours drive to Columbus Ohio to pick up a 120 cm dish at Sadoun than to have them deliver it to you. They also have 30" dishes for $35 a piece.
Gray FC120CM 120CM Satellite Offset Dish antenna FORTEC STAR DVB FTA MPEG2 Free-To-Air Receivers and equipment
Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
I might take a ride to Columbus one of these days, from here it is a bit over 2 hours one way. $35 dishes are a good deal. RTN is on my local LPTV station in Cincinnati. I have to get a separate UHF antenna to aim at it, my main UHF antenna is aimed toward Dayton so I can get both Cincinnati and Dayton locals...unfortunately "WKRP" a/k/a WOTH is just too weak to pick it up here normally.
http://www.wkrp.tv/25-3%20RTV.htm
____________________________________
Retro TV affiliates list
http://www.myretrotv.com/affiliates.html
Register To Reply
