Results 1 to 6 of 11
02-12-2010 07:14 PM #1
Upgrading to a 1000.2...need input please
Currently I have a 110/199 with a 61.5 wing hookup. They run into a DPP33 switch and then to three receivers.
Because of the recent requirement to get 129 in order to get the newer HD channels, i'll need to upgrade to a 1000.2
My understanding is the 1000.2 is not compatible with the DPP33. Will I need a new switch to support 3 receivers or will I be able to run 3 right off the dish. If I want a 4th receiver I'll have to upgrade to a DPP44?
Also, will it be required to run 3 lines out of the dish?Last edited by RedWings; 02-12-2010 at 07:19 PM.
02-12-2010 09:46 PM #2
3 dual or single lnbs / "w" bracket / 3 lines to the 33 switch
or
1000.2 lnb and dish / 3 lines / eliminate the 33 switch (you won't need it with the 1000.2 lnb.)
02-13-2010 07:19 AM #3
Repoint your 61.5 dish at 129
This finger was not made to press 1 for english
02-13-2010 09:55 AM #4
What recievers do you have? What sat do your HD locals come from? The answer to these questions will determine what dish configuration you will need, and what switch.
02-13-2010 10:17 AM #5
- Join Date
- Sep 18th, 2006
- Location
- Leesburg, VA
- Posts
- 841
- Post Thanks / Like
- Thread Starter
02-13-2010 01:22 PM #6I think that the locals HD are on 61.5 but I may be mistaken If that is the case replace the 119/110 for a 1000.2 for 119/110/129. the 129 is low in the sky. all four tie into a DPP44
ADVERTISING BOX
Register To Reply
