Results 1 to 6 of 21
Thread: Motorized or Fixed Dish for FTA?
02-13-2010 08:44 AM #1
Based on feedback from an earlier post, I plan to pick up a 30” to 36” dish for FTA. Given the size, my understanding is that this will restrict me to the Ku band only, which is fine – since a 6’ dish would probably be impractical for me at the moment. I live in the Midwest, by the Wisconsin / Illinois border and my question is, does it make more sense for me to look into a motorized or fixed dish?
From the perspective of basing this decision on what I’m trying to pull in, I looked at a current listing of FTA channels. I imported them into a spreadsheet and sorted, filtering on TV broadcast, Ku Band and English language. The sort indicates that the most bang-for-the-buck in terms of channels are on Sat 123W. Additionally, there are a handful of channels on Sats 101W, 110W, 119W, 125W, and 129W that would also be of interest to me, if possible.
So, there are a few things I’m trying to sort out in my head with regard to motorized or fixed dish setup.
1. If I use a fixed dish, can I pull in 123W from where I live?
2. If #1 is true, could I also pull in any of the other Sats mentioned? (They are not must-have’s)
3. Probably the best question to ask is ‘what’ can I pull in with a fixed dish in my area?
4. Would a motorized dish bring me any additional benefit over a fixed dish?
I realize a blind scan will detect everything available to me when the time comes, but I’m trying to get an idea of this prior to the setup itself. Thanks in advance.
02-13-2010 08:44 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
02-13-2010 09:06 AM #2
I started with a fixed dish on 123w. Unfortunately, that bird is all but dead for FTA viewing. Last year all the good channels got pulled. I have a hard time thinking of one bird I would point at if all I had were a fixed dish. I might start with fixed to get the mechanics down but I would go for a motorized setup in the long run.
I mostly watch 125w, 101w, 97w, 91w, and 89w with a few random things in between.
Browse The List and lyngsat for FTA channels and decide what would be best for your viewing habits.
02-13-2010 09:19 AM #3
As Spiff said there is not a lot left on 123W, but your ability to receive 123W (or any of the other satellites on your list) is determined by your line-of-sight (LOS). That is, you need to have a clear view of the sat, not blocked by buildings, trees, mountains, etc.
You can get a good idea of what sats are visible by doing a site survey, also you might check out Dishpointer.com (link at top of page).
The advantage of a motorized dish is the ability to move from sat to sat from the comfort of your couch, once you have it setup you will be able to view all satellites in your viewable arc.
Lots of folks start with a fixed dish and learn the ropes, then add a motor later, not a bad idea IMO.C-Band: 12' Unimesh/AJAK 180/GeoSat C2***10' "Perfect 10" mesh/GeoSat C2*** 8.5' Birdview solid/BV H-H/GeoSat C2*** 7.5' Unimesh/CalAmp voltage-controlled LNBF***...C-Band LOS from 58W-139W
Ku-Band: 3ABN .9m/SL1PLL LNBF/SG2100***Fortec .9m/TrackerII LNBF/STAB HH90***7.25' Birdview "Spoon"/TrackerII/70:1 BV H-H***Prodelin 1.8m/GeoSat Bullet/AJAK 180 H-H***Paraclipse Hydro 1.5m Prime Focus/Linear Actuator/C120 LNBF...Ku-Band LOS from 30W-129W
Receivers: Toshiba TRX-1820 Analog-->AZBox Elite/Openbox S9 HDx2***GeosatPro microHD
OTA Digital: CM 4228/CM 7777 Preamp/Apex DT-250 for OTA Locals, Toshiba 46" Regza & Toshiba 19" LCDs
In Progress: (2) Birdview 8.5' (1 solid & 1 perf) w/Birdview H-H mounts, "Drake" 10' solid alum....*BVOC Asst. Cook & Bottlewasher*
02-13-2010 11:10 AM #4
I installed my first FTA dish last year (36" dish with a Sadoun 280 motor)
I was concerned that the motor would add to much complexity to the install but I read a lot of post here at SatelliteGuys and got the basics down before I started the install.
I had a couple of questions while pointing the dish and they were answered by the great members here.
If you are willing to do the reading and put in the time on a motorized install I think you will be much happier with your FTA system.
Take care
02-13-2010 11:37 AM #5
Yes, as long as you have a clear line of sight to the satellite with no building, trees, etc.
With a fixed dish and adding additional LNBFs you should be able to cover approximately 20 degrees of the arc (10 degrees on either side of center). Remember, with a fixed dish it is impossible to get 2 degree spacing on satellites without performing some modification to the LNBFs.
See above answer for #2 then reference for "The List" or Lyngsat.com to determine what satellite to place in the center then what side to add the additional LNBFs.
Absolutely! I couldn't imagine only having a single fixed dish for my home system. I keep one fixed 90cm dish to monitor the Glorystar Channels on 97W and 101W and another 90cm fixed dish for 103W (due to the non-standard skew) and a motorized 90cm with QPH-031 LNBF (circular and linear polarity) for covering KU satellites from 58W to 177W.
Great suggestions from the previous posts. I would also recommend that you first install a fixed dish at a single satellite. Learn how your receiver, switches and LNBF works then add a motor. You will probably be quite happy with a 90cm dish, QPH-031 and a motor!Satellite AV, LLC (Gold Sponsor)
Equipment Development / Distribution / Repair / Call Center
888-483-4673 - http://www.satelliteav.com
eBay Special Deals
Attention Installers: Want more work? Join the Largest Satellite Technician Referral Website - www.FTAinstall.com
02-13-2010 11:55 AM #6
SatelliteGuys Freshman
- Join Date
- Feb 10th, 2010
- Location
- midwest
- Posts
- 7
- Post Thanks / Like
- Thread Starter
You guys are awesome! You're giving me enough knowledge to be dangerous, hee hee. I don't know how soon I will actually get to setting this up as a move may be in the near future, but having all of this knowledge ahead of time is a great help. I will be in touch as I progress. Many thanks!
ADVERTISING BOX
Register To Reply
