Quantcast
IR remote not responding
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 5 of 5
  1. #1
    Join Date
    Feb 5th, 2010
    Location
    buffalo,ny
    Posts
    6
    Post Thanks / Like
    I was wondering if anyone else is having a problem with there number 1 IR remote not changing addresses? I received a few calls this morning about this.Every time I went to change the address on the primary the secondary would change and ideas on why this is happening.
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Aug 19th, 2005
    Location
    Some old corn field, United States
    Posts
    1,300
    Post Thanks / Like
    Receiver in single mode?
    Sometimes I miss the old days when we had three channels on the TV, Back then I went to bed at a decent time.
  4. #3
    Join Date
    Feb 5th, 2010
    Location
    buffalo,ny
    Posts
    6
    Post Thanks / Like
    Thread Starter
    nope the ones i checked were in dual mode , had them switch back and forth on the mode but still the #1 remote was changing the uhf address was wondering if ti was a glitch or something else was going on.
  5. #4
    Join Date
    Nov 18th, 2003
    Location
    Los Alamos, NM
    Posts
    1,806
    Post Thanks / Like
    Do menu+menu. Are both remotes set to the same address? If so, then you need to change just one, say the RF one by using RF remote to: Sat for 5 sec, address (1 to 16 or more), press #, view 3 flashes. Then go back and change the IR remote as desired to a different address. Avoid address 1 unless you are using IR from a non-Dish remote with Dish "pre-programmed".
    -Ken
  6. #5
    Join Date
    Feb 5th, 2010
    Location
    buffalo,ny
    Posts
    6
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    I tried that and remote2 was changing address then went back to remote one to try to readdress the same number then a few different numbers and it still was changing the uhf address still doesnt make any sense why this was happening.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
