Quantcast
S2 Bitrate?
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 10
Thread: S2 Bitrate?
  1. #1
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Blindowl1234 did! Help Support The Site And Get Rid of the Syndicated Ads, Blindowl1234 did! If you enjoy the site consider supporting it, Blindowl1234 did! Be COOL like Blindowl1234 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 16th, 2008
    Location
    SouthWest Ohio/East of Cincy
    Posts
    1,690
    Post Thanks / Like
    S2 Bitrate?
    Not sure how to ask this question...On OTA Hd signals the local station could use 18Mbps or so for one channel with no subs...Maybe not 18mbps but something close. What is the typical rate for a signal on FTA S2? or is it that easy to figure out?. I imagine there is quite a varience on FTA HD. I thought I saw an old post on this somewhere but couldn't find it. I know for example Ion Hd and the PBS HD on 125W seems to be even better quality than the HD I get OTA...which to me is quite good already. Hope what I'm asking makes sense? Thanks Blind
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
    Micro HD Receiver, 36" Primestar dish with SG2100 motor & GeoSat PPL Lnb scanning KU from 61W-125W, Fortec 8 Foot with Geosat CK1 Lnb, and HARL2424 Powertech acuator and Gbox scanning 61W-139W, Fixed 6 Ft Fortec dish for 43W-58W.
    Vizio 47" HD/3D Tv with Roku XS and Gateway 3.6Ghz computer for streaming and HTPC. 91XG antenna for 35 plus OTA channels
    My expensive hobbies have helped me keep my sanity and annoyed the neighbors
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Oct 15th, 2008
    Location
    Western Maine
    Posts
    2,029
    Post Thanks / Like
    Quote Originally Posted by Blindowl1234 View Post
    Right.
    A typical OTA channel has the capability for approximately 19.5 mbps bitrate if they just put 1 HD channel, it could occupy nearly that whole space. Where I live, they put 1 HD channel and one low quality weather channel on 2 of the 3 channels, and the other has a SD version of the programming instead of the weather channel. The main HD channel is about 15.5 mbps for the video, and about 0.4 mbps for the audio. Of course, if they tried squeezing more SD channels in there, they would have to compress the main HD channel into a lower bitrate.
    A 1920x1080i OTA HD channel would require over 30 mbps even if it were just white/black with no gray scales or colors, and would be MUCH higher than that with gray scales and colors if not for the MPEG2 techniques and compression. I have no idea of what bitrate completely uncompressed video with complete color info would be, perhaps someone else knows, but the MPEG2 certainly does a good job of getting a lot of info into a reasonable bitrate.
    I have read that the big 3 networks had a policy of starting with at least twice the bitrate of the OTA signal, which is why in the past, CBS network video was approximately 40 mbps for the raw HD, which is more than twice the 19 mbps possible on an OTA station. The AMC21 PBS feeds are about 17.5 mbps, so they apparently don't go by that factor of 2 rule.
    NOW, CBS uses slightly less than the 40 mbps that they used to use {I don't have that feed up right now, but I think it's about 33 mbps), however now they are using 4.2.2, which has more color information, so they must feel that they are making up for the bitrate losses with a higher quality image color wise, I don't know.
    Now, that HD signal can realistically be sent at any bitrate, it's just that as you lower the bitrate, you need to have more MPEG compression, and the quality of the signal gets worse and worse. If they use MPEG4 instead of MPEG2, the same quality video requires approximately 1/2 the bitrate.
    Last time I checked, ABC MPEG4 was around 23 mbps, HDNET was around 18 mbps, Nebraska PBS was around 12 mbps {although when they have the one HD channel using that Huskervision transponder they have over 39 mbps, and I have no idea of whether they have some other source of that, or if they just put AMC21 17 mbps signal out over a 39 mbps channel???}. Dishnet HD in MPEG4 tends to be in the 4 to 6 mbps range, but I've seen it up to 9 at times. I have also seen a full blown MPEG4 1080i HD channel with a bitrate of about 1 mbps, although it was pretty poor quality. So any bitrate is possible.
    Now, re your question, and I don't completely understand what you're trying to ask.... Ie DVB S2 doesn't really have anything to do with the bitrate of the video so much as it gives the uplinkers more room to put a higher bitrate signal there, however generally they end up putting more channels on the transponder rather than higher bitrate on the same channel. DVB S2 allows them to have approximately 1.5 times the bitrate within the same SR transponder. Actually DVB-S2 doesn't allow the 1.5 factor, it's really the 8PSK that's part of the DVB S2 standard that allows it. 8PSK basically allows 2^3=8 bits per symbol vs the 2^2=4 bits per symbol that QPSK allows, minus the overhead requirred for the packaging of the info, thus the 3/2=1.5 factor. (I don't think I worded that quite right, but with 8 on off states, you get 3 bits vs 2 bits with 4 on off states, vs 1 bit with 2 on/off states of BPSK.
    But with the CBS example, switching to DVB S2 8PSK they can fit about 1.5 the info into the same signal, so they have something in the range of 60 mbps available using MPEG2, so they can fit 2 33 mbps signals into the same transponder albeit a bit lower SR rate. The old 30000 SR transponders really had space for nearly 50 mbps, and the new S2 29860 8PSK transponders have room for about 74 mbps, but rather than using all that on one channel they use the space for the 2 33 mbps channels.
    Anyway, other than that, I'm not completely sure what the question is. S2 just gives them 1.5 times as much room for bitrate, and MPEG4 gives them twice the quality for the same bitrate, and the actual bitrate of an HD signal can be virtually anything between 1 mbps to up in the hundreds of mbps without compression.
  4. #3
    Join Date
    Dec 16th, 2008
    Location
    Posts
    1,690
    Post Thanks / Like
    Thread Starter
    Bj, thanks for the info! Yeah you pretty much answered it in the first paragraph or so. The FTA HD stuff looks better than my local OTA Hd.
    Blind
  5. #4
    Join Date
    May 6th, 2005
    Location
    Metro New Orleans, LA
    Posts
    6,269
    Post Thanks / Like
    Quote Originally Posted by B.J. View Post
    Uncompressed SD is around 270 megabits, uncompressed 1080i HD 1.4 gigabits. MPEG-2 and MPEG-4 compression are both wonderful tools, when used properly.
    The problem is that the public in general has been desensitized to low-quality video. I remember when DirecTV first came out, and seeing it demonstrated in a store for the first time, I immediately noticed the macroblocking in fast-moving scenes. People have accepted that as normal, and the consumer content providers have been pushing the envelope with regard to compression and how much they can get by with.
    Current systems: 3X GEOSATpro microHD PVRs; Digitrans DTE-7150 DVB/Digicipher II; SiliconDust HDHomeRun ATSC/QAM networked tuners; fixed 1 meter Channel Master dish with Eagle Aspen P870 FSS stacked Ku LNB; 2X 3ABN 36" dishes with Sadoun KBSL1 stacked Ku LNBFs on Powermax SG-9120B H-H motors; fixed Sadoun SD180G 1.8 meter dish with Eagle Aspen B1SAT stacked C LNBF; Winegard Square Shooter OTA DTV antenna
  6. #5
    Join Date
    Oct 15th, 2008
    Location
    Western Maine
    Posts
    2,029
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Quote Originally Posted by Tron View Post
    THanks for the data. I knew it would be BIG, but wasn't sure how much info they'd have in the uncompressed pixel. I remember back in the early personal computer days, when I'd be real happy with a 1 bit per pixel black/white picture, then getting a few bits of gray scale mixed in. Then the monitors went to color, and we'd have 16 bit color, 256 bit color, up and up. Basically no limit to how many bits you might put in a pixel, but there's obviously points where it's not worth putting more info in there, because you can't see the difference.
    I also remember being on a TVRO group back in the early 90s, and there were several academic type EE's who were quoting equations that related to how much "info" could be put within a set amount of bandwidth, such as a sat transponder or an OTA channel, and the concensus of opinion back then was that you couldn't put HD on a sat transponder, let alone an OTA channel. I think MPEG and then 8PSK put an end to trusting those theories.
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! merkin did! Help Support The Site And Get Rid of the Syndicated Ads, merkin did! If you enjoy the site consider supporting it, merkin did! Be COOL like merkin and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 31st, 2009
    Location
    illinois
    Posts
    79
    Post Thanks / Like
    ADVERTISING BOX
    Online Satellite Calculations - 20©07 Jens T. Satre
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    8th one down, but all are neat.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
