Quantcast
aligning a slimline dish
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 7
  1. #1
    Join Date
    Feb 2nd, 2008
    Posts
    Post Thanks / Like
    This has probably been covered somewhere in here but I can't find it anywhere. I'm in Pt. Roberts WA and get really good readings on everything but the 99.2
    Is there a way to isolate just that satellite to tweak the signal strength? I was told that I need to reduce the good numbers to boast the low one, but that has not seemed to help.
    Any suggestions?
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Nov 24th, 2009
    Location
    Raleigh, NC
    Posts
    59
    Post Thanks / Like
    Quote Originally Posted by toyboxgang View Post
    Any suggestions?
    Try changing the skew by 1 degree cw or ccw, when you balance 99 and 103, you're good
  4. #3
    Join Date
    Feb 2nd, 2008
    Posts
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by WhoRay85 View Post
    Thanks for the tip. What do you mean by skew? is that elevation, bearing or tilt?
    I am able to get into the 80's on the 103, but only the high 40's on the 99.
  5. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! raoul5788 did! Help Support The Site And Get Rid of the Syndicated Ads, raoul5788 did! If you enjoy the site consider supporting it, raoul5788 did! Be COOL like raoul5788 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 28th, 2004
    Location
    Cheshire CT
    Posts
    12,160
    Post Thanks / Like
    Tilt and skew are the same thing. Bearing is really azimuth, and elevation is elevation! At least according to Directv anyways!
    BTW, my name is Chip, Raoul5788 is just a screen name
  6. #5
    Join Date
    Nov 24th, 2009
    Location
    Raleigh, NC
    Posts
    59
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Skew is tilt.
    If you're only in the 80's on 103, those aren't the greatest numbers, ideally, you want mid to upper 90's on all Sat's. Might be best if you can find a local installer to dither your dish.
  7. #6
    Join Date
    Dec 28th, 2004
    Location
    Cheshire CT
    Posts
    12,160
    Post Thanks / Like
    ADVERTISING BOX
    Skew is tilt.
    Depending on where the op is, 80's may be the best he can get. Those in SoCal have generally lower signal strengths. 80's is okay, but higher is better in marginal conditions, like heavy rain. For normal weather, it's fine.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
