Quantcast
HR-24 AND SWM DISH
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 1 of 2 12 LastLast
Results 1 to 6 of 7
  1. #1
    Join Date
    Jun 19th, 2010
    Location
    Montreal
    Posts
    8
    Post Thanks / Like
    HR-24 AND SWM DISH
    I recently self installed a 5 lnb swm dish to my new hr-24 dvr receiver but have a strange problem.I am only getting a signal on tuner 2 and not on tuner 1.All my levels seem to be good on 99,101 and 103,but I cannot get anything on 110 or 119 due to some trees.Even though,when I first set up system,I had signal to both tuners for about 15 minutes,and then only tuner 2 would get a signal.I believed it was a wire or connection issue and changed the wire and same thing,good signal for about 10 minutes and then only tuner 2.Could the fact that I am not getting signal from 110 and 119 be doing this?Could it be bad lnb or power inserter?I hooked up my friends receiver and same thing happenned so it is not the box and I tried an older 5 lnb ka/ku lnb with bbc on both cables coming and both tuners worked perfectly all night.There is no swm spliter involved either,only one receiver in my set up. I know these swm lnbs are tricky but this one has me stumped.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! raoul5788 did! Help Support The Site And Get Rid of the Syndicated Ads, raoul5788 did! If you enjoy the site consider supporting it, raoul5788 did! Be COOL like raoul5788 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 28th, 2004
    Location
    Cheshire CT
    Posts
    12,261
    Post Thanks / Like
    Quote Originally Posted by Leeza View Post
    Just guessing, but it sounds like you have a bad lnb to me.
    BTW, my name is Chip, Raoul5788 is just a screen name
  4. #3
    Join Date
    Jul 31st, 2009
    Location
    State of Jefferson
    Posts
    1,249
    Post Thanks / Like
    Just to be sure, you connected the cable from the dish to the input on the receiver marked "1(SWM-2) and you have nothing connected to input 2?
    After you connected it did you go through the entire satellite setup process once again?
  5. #4
    Join Date
    Jun 19th, 2010
    Location
    Montreal
    Posts
    8
    Post Thanks / Like
    Thread Starter
    Yes I did exactly all that and still nothing.Get signal for both tuners for about 10-15 minutes and then only on tuner 2.I fixed the problem by getting an older ka/ku 5 lnb and 2 b-band converters and it works fine.Still do not know what I was doing wrong with the swm lnb,but I am a happy camper now with the other lnb.
  6. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Jimbo did! Help Support The Site And Get Rid of the Syndicated Ads, Jimbo did! If you enjoy the site consider supporting it, Jimbo did! Be COOL like Jimbo and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 14th, 2005
    Location
    NW Ohio - Buckeye Country
    Posts
    42,223
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    If you put an older LNB on and it worked, it sounds like the SWiM portion was not working as the voltage to the LNB is supplied by the recvr normally and from the Power Inserter with the SWM.
    The LNB needs to see the higher voltage with the SWM, I would take a guess and say it's a PI problem....
    You got it working with the old set up, only difference is you need 2 lines for the old set up, are you still trying to get it going using the SWM ?
    You did go thru the Re Set Up Sat configuration in the SAT and Antenna menu, right ?
    Thats where it finds the SWM set up and makes the changes.
    2 HR24-500's, 2 HR24-100's, SL3 Dish, SWM Dish, AM21, 60" Pioneer Elite, 2 - 42" Pioneer Elite's, Seagate 1.5 TB EHD
  7. #6
    Join Date
    Jun 19th, 2010
    Location
    Montreal
    Posts
    8
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    I put my swm lnb,power inserter and the swm splitter in a box and am no longer trying to get it to work.I only have one receiver so it was just an extra wire and the 2 b-band converters.I tried everything that I could think of and every suggestion that I got from here and other forums,all to no avail.It works fine with the old set up,so I am not going to play with it any longer.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
