Page 1 of 4 123 ... LastLast
Results 1 to 6 of 19
Thread: Channel change from another room possible?
  1. #1
    Join Date
    Aug 5th, 2010
    Location
    Indiana
    Posts
    Post Thanks / Like
    I am currently a Dish customer, but am disenchanted and contemplating the switch. The only thing I truly like is the ability to change the channel of the receiver that is ran to two tvs, with HD mirrored off the HDMI and component, from a different room using RF.
    From all that I have gathered, the DTV receivers use IR. Is there any way to change the channel from another room using a remote eye or different method ?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Apr 10th, 2009
    Location
    California
    Posts
    1,490
    Post Thanks / Like
    You can change the directv remote to RF, or you could use an IR remote transmitter.
  4. #3
    Join Date
    Sep 8th, 2003
    Location
    Springfield, IL
    Posts
    2,546
    Post Thanks / Like
    All HD DVR's come standard with RF remotes that just need to be enabled in RF mode.
    All HD receviers & SD DVR's have RF capability, but only come with IR remotes; you can buy RF remotes for about $20-$25.
    The SD receivers are IR only.
  5. #4
    Join Date
    Aug 5th, 2010
    Location
    Indiana
    Posts
    Post Thanks / Like
    Thread Starter
    Thanks, sounds like that may be the driving force behind the change!
  6. #5
    Join Date
    Apr 10th, 2009
    Location
    California
    Posts
    1,490
    Post Thanks / Like
    One thing that might be different. I think the dish receivers can output two different shows at the same time to two different tv sets? Directv only outputs one.
    One other thing you can do is that if you have an HD DVR and an HD receiver, the stuff recorded on the HD DVR can be streamed to the HD receiver and watched locally. Then you can watch separate stuff on each tv. If you opt for this setup, you'll also be more likely to get the very latest directv receivers/dvr's instead of an older model.
  7. #6
    Join Date
    Mar 18th, 2004
    Location
    Cookeville, TN
    Posts
    249
    Post Thanks / Like
    I didn't know I could use my present remote for RF. I just enabled it for RF and have a HR22. It worked great but I don't see any place for an RF antenna, but it doesn't seem to affect it. Works great without an antenna.
    lem52
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
