Results 1 to 6 of 15
Thread: A newbie question
08-14-2010 09:12 PM #1
A newbie question
I have decided on RG11 for my cable, now the other questions i have
what FTA receiver can do mpeg2 and mpeg 4 with scanning and has a connection so i can add an external hard drive and turn it into a dvr?
can a large cband dish see programs from SatelliteGuys.US_TheList - TheList in medium listings too ?
what motor and ku and c--band feedhorn / lnb is best ?
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
08-14-2010 09:12 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
08-15-2010 05:08 AM #2
RG-11 is great cable, and does very well for long runs, but is not really needed unless you're going to go more than 150 feet or so. It requires special compression fittings, and only some of the compression tools will do RG-11. Not trying to talk you out of RG-11, just pointing out some of the requirements you will encounter.
To answer your question about a receiver, the Solomend (Sathawk) will do both MPEG-2 and MPEG-4, and has excellent blind scan. It has a nice price point, but there are some issues that still haven't been worked out with the box regarding display and recording of high bitrate feeds. The AZBox will do MPEG-2 and MPEG-4, but I'm not sure whether the higher models have true blind scan or not. It also has problems with recording high bitrate feeds.
A C-Band dish will receive channels from the medium listings (Ku-Band) if you use a combination C-Ku band LNBF. There have been issues reported by many members with getting both C-Band and Ku-Band aligned correctly at the same time. I would not necessarily recommend such a setup for someone just starting out, however, some have had acceptable results.
I'll let other members tackle the motor and feedhorn question, as my C-Band dish is stationary.Current systems: 3X GEOSATpro microHD PVRs; Digitrans DTE-7150 DVB/Digicipher II; SiliconDust HDHomeRun ATSC/QAM networked tuners; fixed 1 meter Channel Master dish with Eagle Aspen P870 FSS stacked Ku LNB; 2X 3ABN 36" dishes with Sadoun KBSL1 stacked Ku LNBFs on Powermax SG-9120B H-H motors; fixed Sadoun SD180G 1.8 meter dish with Eagle Aspen B1SAT stacked C LNBF; Winegard Square Shooter OTA DTV antenna
08-15-2010 10:14 AM #3
SatelliteGuys Freshman
- Join Date
- Aug 14th, 2010
- Location
- o
- Posts
- 8
- Post Thanks / Like
- Thread Starter
By compression fittings, do you mean the connectors you put on the ends of the cables used to hook them into the tv and boxes and the dish itself ?
So those 2 boxes are the best ?
Why is it hard to align c band and ku band at same time ? do you mean when you try to have 2 sats aligned to view the material or when try to simlpy move to their orbital locations ?
Also will any boxes have hdmi 1.4 ? i do not care about 3d, i just like having the latest specs.
After viewing the boxes you mentioned, they look pretty good the Solomend (Sathawk) controls the motor too, just to look at other receivers why are their so many different ones ?Last edited by joray85; 08-15-2010 at 10:19 AM.
08-15-2010 10:16 AM #4Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
All FTA stuff in storage right now
08-15-2010 10:23 AM #5
- Join Date
- Aug 14th, 2010
- Location
- o
- Posts
- 8
- Thread Starter
Also with the ethernet allow us to MRV ?
also do any have 10/100/1000 ethernet ?
how does the Streethawk FTA box rate vs theSonicview 8000 HD ?
I wish their was a site where all FTA boxes features ARE listed with check boxes so a person could check the ones they want then click ok then the site matches you to a box that is closest to what the consumer wantsLast edited by joray85; 08-15-2010 at 10:32 AM.
08-15-2010 10:25 AM #64:2:2 is chroma subsampling...basically the way the signal is sent
ADVERTISING BOX
4:2:0 is "normal" and all FTA receivers can see 4:2:0
4:2:2 is different. While the channels will scan in unless you have a receiver that does 4:2:2 all you'll see on the screen is a "tearing" on the screen. No picture just sound
noAlso with the ethernet allow us to MRV ?
also do any have 10/100/1000 ethernet ?Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
Register To Reply
