Page 1 of 5 123 ... LastLast
Results 1 to 6 of 25
Thread: No channels on V polarity
  1. #1
    Join Date
    Sep 19th, 2010
    Location
    Russia
    Posts
    10
    Post Thanks / Like
    Hi all. The reason why I am asking for help on the forum is a problem with sat dish setup that I have had for the last month. Half a year before it, It had been working fine. But a month back one day I could not find around half of channels. Trying to scan again, I noticed that I cannot find channels of V polarity. Only H.
    I am using tv tuner Technisat Skystar HD 2 PCI in my PC and circular LNB. Software - DVBViewer Pro.
    By now I have tried as follows:
    - Tried to install the tuner into other computer. No result.
    - Returned the tuner to shop and got a new one. No result.
    - Changed LNB to a new one. No result.
    - Checked voltage from the both tuners (the old returned one and the new one). It changes from 13 to 18 and back.
    - Checked voltage on the end of cable going from the tuner to LNB. Voltage changes.
    What else can be a problem? I do not understand. Any help appreciated.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    May 27th, 2008
    Location
    San Diego, California
    Posts
    378
    Post Thanks / Like
    Get another receiver and check that, if it fails to get the "H" channels, then you might as well have a defective LNB or a bad cable run... altough using a circular LNB there is not much, if any, that can be received.
    Cheers
    Mike
  4. #3
    Join Date
    Sep 19th, 2010
    Location
    Russia
    Posts
    10
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by Mikhel View Post
    Cheers
    Mike
    Another reciever? As i wrote, I returned old reviever to store and got a brand-new one but the problem still exists. The same about LNB. Tried two LNBs.
  5. #4
    Join Date
    May 27th, 2008
    Location
    Posts
    378
    Post Thanks / Like
    Yup another receiver (a STB), to discard anything related to the DVB card.
  6. #5
    Join Date
    May 12th, 2008
    Posts
    538
    Post Thanks / Like
    Hi Flighttothemoon, are you located in Russia? What satellite are you trying to receive?
    FYI - a circler LNB will not pick up H or V polarity very well, it should only be used on a satellite with circler L or R polarity.
    How did you test the voltage at the LNB? I think you might have a bad cable run that is loosing voltage under load. Maybe try using a barrel connector at the LNB and add a short piece of coax with a slot cut in the side so you can test with the LNB hooked up.
    Hope this helps, DC
  7. #6
    Join Date
    Sep 19th, 2010
    Location
    Russia
    Posts
    10
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by delta_charlie View Post
    Hope this helps, DC
    Hi. Yes, located in central Russia and trying to recieve Eutelsat W7 36E.
    As to cable, using digital meter, I tested voltage straight from tuner and from the end of cable that goes from tuner, before it goes to LNB. In both cases, voltage changes 13/18. Can it still be the problem in cable if voltage is ok?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
