Results 1 to 6 of 8
09-25-2010 09:35 AM #1
trouble locking satellite signals
hi,guys i am at my wits end,i have everything set up for all satellites,thats programed in my receiver,lnb configuration is set etc. when i go outside and turn my dish with my satellite finder,i get a good signal,go back inside,scan my satellite....nothing...i have been doing this all day,yesterday i received the pentagon channel and have not received any thing else is it any thing i am doing wrong,.....i need help
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
09-25-2010 09:35 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
09-25-2010 09:45 AM #2
Try taking sat receiver and a small tv out to the dish connected with a short cable and try again. This way you can SEE what your signal meter is seeing.
EDIT:
Duh, I didn't see that you double posted this yesterday and already got the same answer as mine.
http://www.satelliteguys.us/free-air...ml#post2335993Last edited by Pixl; 09-25-2010 at 10:07 AM.
09-25-2010 10:02 AM #3
I will echo TantalusFld's comments. Take the satellite receiver and small TV out to the dish so that you can see on screen what the signal quality meter in the receiver shows. I've tried using some cheap $10 satellite finders, and have found that they're not very helpful. I use the satellite signal quality meter on screen to watch for when I've got signal.
09-25-2010 10:08 AM #4
ICU,
A question to you... Are you setting up a single, fixed point dish or a motorized dish?
If a single, fixed point dish, which satellite are you trying to pull in?
If you are setting up a motorized dish, what are your site's coordinates and which satellite do you percieve to be your nearest true south satellite?
Also, what LNBF and dish and receiver do you have?
If you are using a motor, which motor make and model?
RADARLast edited by AcWxRadar; 09-25-2010 at 10:15 AM.
09-25-2010 12:03 PM #5
SatelliteGuys Regular
- Join Date
- Aug 31st, 2010
- Location
- lower alabama
- Posts
- 262
- Post Thanks / Like
- Thread Starter
hi,iam setting up a fixed dish,have a standard lnb, and have what i perceived to be the same 39" dish as a omega sat,which came from canada and a orasat 5.0 don't laugh i will update later...but let me ask you one thing...i am going right into my existing dish network wiring that's going into the house,i have disconnected the dish entirely,would this keep the info from from the dish from entering the receiver,like i said i did get the pentagon channel the other day.
09-25-2010 12:15 PM #6I'd think the wiring is ok as you said "I got the Pentagon Channel" Have you tried using
ADVERTISING BOX
Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
to find your desired sat? Don't forget, with a Az-El mount, you also have to "skew" the LNB.Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
10Ft USS Steel BUD and an assortment of P⭐ dishes, 84e(1), .7m(2), 1.2m(2). 2.4m[8ft](1) offset in storage. 🐱
Register To Reply
