Results 1 to 4 of 4
Thread: Convert from dishpro to legacy
  1. #1
    Join Date
    Jan 13th, 2005
    Posts
    4
    Post Thanks / Like
    I have a 301 that is currently using a dishpro lnb. I think the lnb is bad, as I all of a sudden can't get anything off of 110. I have an old legacy setup that I was going to try, with the SW21s to go with it. I remeber reading something long ago about having to clear the 301 to do this and avoid burnig the legacy lnbs because of voltage or something. I searched the forum to find how to do this, but couldn't find it. Any help would be appreciated.
    Thanks from a long time lurker.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! boba did! Help Support The Site And Get Rid of the Syndicated Ads, boba did! If you enjoy the site consider supporting it, boba did! Be COOL like boba and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 12th, 2003
    Location
    Dorchester, TX.
    Posts
    9,048
    Post Thanks / Like
    Just disconnect the cable going to the dish from the receiver. Then all you have to do is run a switch test so it comes back no switch detected. Connect the Legacy equipment and run a switch test to detect the Legacy equipment.
  4. #3
    Join Date
    May 22nd, 2004
    Posts
    56
    Post Thanks / Like
    Arrow
    Quote Originally Posted by LookIPosted
    It's not so much a voltage issue, because DP receivers can run just fine off Legacy LNBFs. A bigger problem you might have is the 301 recognizing the downgrade to Legacy. We have had problems with 311/301's that have been running on DP or Legacy LNBFs for so long that for some reason (we believe) the software gets so used to the configuration that even when setting the receiver back to factory defaults it will have issues recognizing the new config.
    If you have the old legacy equipment, give it a shot because it costs a lot less than replacing the DP LNBF. But again, don't worry about the voltage. In fact, I've noticed that for some strange reason 522 receivers run a heckuva lot more stable on Legacy Quads or Twins than on DP Quads or Twins. But then again, this is just something me and the guys just notice... no hard data to back this theory up.
    Hope this helped.
  5. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! SimpleSimon did! Help Support The Site And Get Rid of the Syndicated Ads, SimpleSimon did! If you enjoy the site consider supporting it, SimpleSimon did! Be COOL like SimpleSimon and Click a Star and become a Supporting Pub Member today!
    Join Date
    Feb 29th, 2004
    Location
    Florissant, CO
    Posts
    5,691
    Post Thanks / Like
    BlueBoar: it IS a voltage issue. You DO have to worry about it.
    DP runs on higher voltage than Legacy, and sometimes the excess juice can fry an old weak Legacy LNBF. Rare, but it does happen.
    LookIPosted: Clear the switch matrix using AT LEAST boba's procedure - although that doesn't always work on all receivers. Safer to do the full monty: Unplug feeds, Check Switch. Pull Power. Check Switch AGAIN. Reconnect sat feeds. Check Switch to get-r-done.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
