Page 1 of 2 12 LastLast
Results 1 to 6 of 8
Thread: smallest size dish for 58W satellite
  1. #1
    Join Date
    Oct 10th, 2009
    Location
    pa
    Posts
    14
    Post Thanks / Like
    I live in eastern Pa. What would be the smallest dish I can use to get 58W intelset 9 7/8 fec signal? TIA
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! FaT Air did! Help Support The Site And Get Rid of the Syndicated Ads, FaT Air did! If you enjoy the site consider supporting it, FaT Air did! Be COOL like FaT Air and Click a Star and become a Supporting Pub Member today!
    Join Date
    Feb 27th, 2010
    Location
    97W 48N
    Posts
    4,272
    Post Thanks / Like
    I use a 10 ft. Maybe a member in that part of the country gets good results with something smaller. But for me, the I'd want the biggest, within reason, I got room for. If it's something that you want to have dependably, why risk getting just a marginal signal?
    One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
    Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
    10Ft USS Steel BUD and an assortment of ChannelMaster dishes, (1)84e, (2).7m, (2)1.2m,(1)1.0M, (1)2.4m[8ft] offset in storage.
  4. #3
    Join Date
    Oct 12th, 2008
    Posts
    1,075
    Post Thanks / Like
    I easily get everything on 58W with a 1.8m (6') dish. To be fair I've got a relatively high-end feed and LNBs on it, and it is carefully adjusted. Looking at the numbers, a 1.2m (4') might get some of the stronger, lower FEC feeds, but probably not the one you're looking at (it would be helpful to know which transponder you're after).
  5. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Iceberg did! Help Support The Site And Get Rid of the Syndicated Ads, Iceberg did! If you enjoy the site consider supporting it, Iceberg did! Be COOL like Iceberg and Click a Star and become a Supporting Pub Member today!
    Join Date
    Nov 17th, 2003
    Location
    Parts Unknown
    Posts
    89,825
    Post Thanks / Like
    7/8 FEC?
    6 foot MINIMUM...and thats pushing it
    8 foot recommended
    The 7/8 FEC feeds need more signal to stay stable over the normal 3/4 FEC feeds
    what channels are you looking to get?
    FOLLOW THE BUZZARDS.....
  6. #5
    Join Date
    Oct 12th, 2008
    Posts
    1,075
    Post Thanks / Like
    Of course we all would like to have the biggest dish that could fit/be acceptable, however OP asked for the smallest dish that would do the job. I've found that make/break for people getting into C-band often revolves around the size of the dish. I wouldn't want to mislead someone into thinking a 1.8m would get every tough feed out there, but I also wouldn't want to discourage someone by insisting they must use a larger dish when a small one would suit the purpose.
    58W is probably our most favorite bird and we keep our 1.8m on it almost all of the time. Its 7/8 FEC transponders are a walk in the park for us, and we have a fair amount of link margin - between 1-2 dB in the worst cases. The only time we have had reception problems in the past couple of years is when the dish got iced up and covered with snow. If only the lower third was covered, everything still worked fine.
    I should point out we're near Denver and 58W is only at a 24 degree elevation, meaning our 1.8m is picking up some thermal noise from the earth. In PA the elevation is going to be more like 40 degrees, which should help reception. In terms of 58W's power contours, Denver probably receives a bit more power than PA, but the difference is probably on the order of 0.5 dB.
  7. #6
    Join Date
    Oct 10th, 2009
    Location
    pa
    Posts
    14
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by Iceberg View Post
    7/8 FEC?
    arirangtv
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
