Results 1 to 3 of 3
Thread: Dual lead XM antenna to single input receiver?
  1. #1
    Join Date
    Oct 19th, 2010
    Location
    WA
    Posts
    Post Thanks / Like
    I am installing a Pioneer XM receiver in my custom 1957 Chevy truck project. I also have a late model Cadillac antenna with through the roof wires, it has the dual lead setup with the mustard FAKRA male plug satellite signal and the green FAKRA male plug terrestrial signal.
    The Pioneer antenna wire has a pink FAKRA female connector.
    The Pioneer antenna is a magnetic mount, the Cadillac antenna is paintable and will be a cleaner installation if I can make it work.
    I believe that I only need to connect the mustard colored satellite wire from the Cadillac antenna to the Pioneer unit, but I am not positive. I have read that the newer XM receivers receive both the satellite signal and terrestrial signal through the satellite lead.
    Also, I have not been able to find any kind of adapter for this application. I think I need a adapter with a female mustard FAKRA connector at one end and a female pink FAKRA connector at the other end. Is this something that can be ordered or made?
    I would really appreciate any help. Oh, I've tried the dual lead adapter below, but it had male connectors on the input side rather than female connectors.
    XM Satellite Radio at MyRadioStore - Antennas & Extensions - Adapters, Splitters, and Extensions - Vehicle Factory Dual Lead Antenna to XM/Sirius Adapter
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Sep 17th, 2004
    Location
    Charleston wv
    Posts
    3,769
    Post Thanks / Like
    Maybe this may help? AWTATMjTBsLelgeThM8p&ved=0CBgQ8gIwAg#
  4. #3
    Join Date
    Oct 19th, 2010
    Location
    WA
    Posts
    Post Thanks / Like
    Thread Starter
    If that was a link, it doesn't show up in my browser.
    I found custom cables to connect the dual cable antenna to the single input Pioneer XM receiver.
    Am I correct that the only signal I need from the antenna is the satellite signal, and the terrestrial wire is no longer necessary to hook up?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
