Results 1 to 6 of 6
Thread: Full Factory Reset on 722k?
  1. #1
    Join Date
    Jan 25th, 2006
    Posts
    151
    Post Thanks / Like
    Is there a way to do a full factory reset on a 722k? I have done the menu for Factory Defaults, but it doesn't really do anything except for the settings. I would like to try to get my homeline phone plug working again, and would like to try that. Thanks!
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! navychop did! Help Support The Site And Get Rid of the Syndicated Ads, navychop did! If you enjoy the site consider supporting it, navychop did! Be COOL like navychop and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 20th, 2005
    Location
    Northern VA
    Posts
    29,066
    Post Thanks / Like
    Best suggestion may be to unplug for a minute, replug it in. Might also try a check switch with the satellite inputs removed, then again with them hooked back up.
    Reunite Pangaea!
    Appreciate my posts AND thinking of Signing Up for DISH? Please consider using one of my referral codes below and we will both save $50 on our DISH bill!
    DRD703497211 / DRD592770150 / ADP0029743389
    To redeem the code go to http://tinyurl.com/dishreferral or you can call 888-284-7103 or your local participating DISH retailer!
    (If you use one of my codes THANK YOU! Please PM when you use the code so I can remove the used code!)
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Hall did! Help Support The Site And Get Rid of the Syndicated Ads, Hall did! If you enjoy the site consider supporting it, Hall did! Be COOL like Hall and Click a Star and become a Supporting Pub Member today!
    Join Date
    Feb 14th, 2004
    Location
    Germantown OH
    Posts
    11,631
    Post Thanks / Like
    Quote Originally Posted by rodin View Post
    Someone's posted some obscure key sequence using the remote that works for the 522/625 and it's possible it also works on other receivers. I'll try and search for it...
    Running a check-switch with the satellite connections un-hooked won't help. That clears the satellite input "matrix".
  5. #4
    Join Date
    Feb 14th, 2004
    Location
    Germantown OH
    Posts
    11,631
    Post Thanks / Like
    Reset Procedure:
    1. Turn on the receiver
    2. On the remote, press MENU then 6 and then 1 (or 3 ?)
    3. On the remote, press the following sequence: INFO then BROWSE then THEME
    4. Press the TV/VIDEO button, and then the ird's Front power button
    5. The receiver will reboot, flush its memory and redownload its software
    6. Now your receiver is RESET to Factory defaults
  6. #5
    Join Date
    Jan 25th, 2006
    Posts
    151
    Post Thanks / Like
    Thread Starter
    Thanks to the both of you. Unfortunately none of those worked. I am actually kind of suprised that they do not have a way to do a "true" factory reset on these systems.
  7. #6
    Join Date
    Nov 8th, 2009
    Location
    Kansas
    Posts
    357
    Post Thanks / Like
    If you go to the system info screen as HALL says, and press "Info" "Right" "Left" that will pop up a message. Do a hard reset and that will reset everything for you. You must be doing it wrong or something. What can you not do with the homeplug. Hard reset wont help anything.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
