Quantcast
[VOOM] Antenna question
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 5 of 5
  1. #1
    nostrodumb_ass Guest
    Currently, I have an 25 db gain antenna "distribution amplifier"
    monted in my basement to compensate for a long cable run. To my
    knowledge, I do not have a "preamplifier" mounted on my outdoor
    antenna. (Voom installed, 10' boom Channel Master yagi style.)
    Our local ABC, FOX and NBC stations are on and off reception (mostly
    off).
    Would one of these mast or antenna mounted preamplifiers help pull
    in these signals?
    Thanks.
    -k
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
  3. #2
    David Lay Guest
    Re: [VOOM] Antenna question
    I've used this antenna amplifier with pretty good results:
    http://www.radioshack.com/product.as...t%5Fid=15-2507
    Cheers,
    Dave
    > off).
    > in these signals?
    > Thanks.
    > -k
    > *Yahoo! Groups Links*
    > * To visit your group on the web, go to:
    > http://groups.yahoo.com/group/VOOM/
    > * To unsubscribe from this group, send an email to:
    > VOOM-unsubscribe@yahoogroups.com
    > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
    > Service .
  4. #3
    thegrod Guest
    I would run, not walk and get a Channel Master or Winegard Mast amp LIke an
    AP8275 appropriate to the type of antenna and antenna hookups you have and
    install it as close to the antenna as you can but leave enough wire for a
    drip loop. Unless you are going over 100' I would get rid of the
    distribution amplifier first and then add it only if you really need it
    because it could hamper digital reception by amplifying noise as well as
    signal.
    Do not use Radio Shack product for this. It is just not at the same level
    of performance. A rotor is important too if your signals come from
    multidirections.
    ----- Original Message -----
    To:
    Sent: Tuesday, January 18, 2005 11:37 AM
    Subject: [VOOM] Antenna question
    > off).
    > in these signals?
    > Thanks.
    > -k
    > Yahoo! Groups Links
  5. #4
    [VOOM] Re: Antenna question
    Don't the mast amps and rotors need their own power sources? Now I
    need to run power 25 feet up to my antenna?
    -k
    amp LIke an
    have and
    wire for a
    need it
    well as
    > signal.
    same level
    from
    > multidirections.
    > From: "nostrodumb_ass"
    > To:
    (mostly
    > > off).
    pull
    > > in these signals?
    > > Thanks.
    > > -k
    > > Yahoo! Groups Links
  6. #5
    thegrod Guest
    Re: [VOOM] Re: Antenna question
    ADVERTISING BOX
    Yes, but not exactly as you may think.
    The mast amp power comes up to the mast amp via coaxial cable from a power
    supply located inside the house. By the same token the amplified signal
    from the mast amp outside comes down that same coax to the power supply unit
    and is fed from there to the TV or STB.
    The rotor is powered by a 3 conductor color coded cable to the rotor at the
    antenna mast. The voltage is a pulsed type voltage around 30 volts. The
    conductors are relatively thin. I have about 500' of this cable Channel
    Master brand so if you need some I can probably supply it to you cheaply
    because I can't use it all.
    It's really pretty simple. Google Winegard and Channel Master sites for
    better insight.
    To:
    Sent: Tuesday, January 18, 2005 2:07 PM
    Subject: [VOOM] Re: Antenna question
    > -k
    > amp LIke an
    > have and
    > wire for a
    > need it
    > well as
    >> signal.
    > same level
    > from
    >> multidirections.
    >> To:
    > (mostly
    >> > off).
    > pull
    >> > in these signals?
    >> > Thanks.
    >> > -k
    >> > Yahoo! Groups Links
    > Yahoo! Groups Links
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
