Results 1 to 5 of 5
Thread: Moving VIP222K to the TV2 room, making it TV1 (have diagram)?
  1. #1
    Join Date
    Dec 12th, 2010
    Location
    Nashville, Tn
    Posts
    Post Thanks / Like
    So I have a VIP222K that provides tv1 to the TV in the same room and tv2 in another room. I want to move the VIP222K into that other room, seems super easy....
    I went out to the box on the side of the house where I have two cables coming from my Satellite, connected to two DPD2 Sat/VHF splitter things. One of them is feeding my downstairs VIP722, I left this one alone.
    The other DPD2 has a VHF and Sat line coming out of it. the VHF line goes upstairs to my TV2 room and the Sat line goes to the room with the VIP222K.
    I reversed these two out at the box. Next I moved the VIP222K and all the junk behind it to the TV2 room.
    No matter how long it sits, it never picks up any satellites.
    I am attaching a diagram of what it looks like before I changed anything:
    - I have reversed the connections at DPD2 labeled ITEM 1
    - I have moved the receiver and all the junk labeled at (and below) ITEM 2
    Any tips on what simple mistake i've made will be great!
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Dec 1st, 2008
    Location
    On Your Roof!
    Posts
    910
    Post Thanks / Like
    you almost have it on item a the one that is sat needs to be conected to the dish and the other side if the diplexer with one conection needs to go to the room with the 222 . item b looks spot on.
  4. #3
    Join Date
    Jun 7th, 2010
    Location
    PA
    Posts
    563
    Post Thanks / Like
    Even though item A is wired wrong, it should still allow sat signal thru, but you probably don't have any picture on TV2
  5. #4
    Join Date
    Nov 8th, 2009
    Location
    Kansas
    Posts
    357
    Post Thanks / Like
    Quote Originally Posted by TimberWolf View Post
    Yeah, but it's still wired wrong. All you need to is having the single side of the diplexer that says IN/OUT go to where you want the 222. The port labeled sat should be connected to a line coming from ur dish.
  6. #5
    Join Date
    Dec 12th, 2010
    Location
    Nashville, Tn
    Posts
    Post Thanks / Like
    Thread Starter
    Yeah you are 100% correct about that being wired wrong and thanks SO much for pointing that out. I just assumed that the one coming in was the dish and the two going out were for the IRD and the TV2. I swapped the one going into the DPD2 and the Sat line and everything worked perfect.
    Thanks again.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
