Quantcast
Error 122: Internal Communication Failure
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 10
  1. #1
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! GaryPen did! Help Support The Site And Get Rid of the Syndicated Ads, GaryPen did! If you enjoy the site consider supporting it, GaryPen did! Be COOL like GaryPen and Click a Star and become a Supporting Pub Member today!
    Join Date
    Mar 2nd, 2004
    Location
    I LIVE in California. I'm FROM Brooklyn.
    Posts
    13,961
    Post Thanks / Like
    I recently received a replacement 722k for one that died. It powers up, which is a nice change from the one it's replacing. But, it keeps popping up an error 122 message. Very annoying.
    None of the others that are hooked up to the same dish/LNB/switch do this. That, combined with what little I've been able to find on this forum, leads me to believe it's a problem in this particular receiver, and not in any external parts of the setup.
    Can anyone here confirm or deny that error 122 is indeed only triggered by an internal problem, and most likely means the receiver is defective.
    Gracias beaucoup.
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! TheKrell did! Help Support The Site And Get Rid of the Syndicated Ads, TheKrell did! If you enjoy the site consider supporting it, TheKrell did! Be COOL like TheKrell and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 4th, 2007
    Location
    Fairfax, VA
    Posts
    7,092
    Post Thanks / Like
    I see this detail on the tech portal:
    Symptom
    Error 122
    Cause
    This message occurs when the internal Smart Card has an error. The Smart Card number may be entered wrong on the account.
    Prevention
    Verify the Smart Card numbers are correct when activating a receiver.
  4. #3
    Join Date
    Mar 2nd, 2004
    Location
    Posts
    13,961
    Post Thanks / Like
    Thread Starter
    Thanks. It seems to check out. But, I'll give them a call to double-check.
    I've also gotten error 15 "complete signal loss" a couple of times. But, the other receivers are seeing the signal just fine are working fine.
    I wonder if it's related to the OTA module? I know I used to get satellite signal loss warnings when OTA signal was lost even though I wasn't watching or recording an OTA channel.
  5. #4
    Join Date
    Mar 2nd, 2004
    Location
    Posts
    13,961
    Post Thanks / Like
    Thread Starter
    Also, it seems to forget my lock password after I unlock the system. When I go to lock it again after making my changes, it asks me to create a password, as if its the first time I've used locks. I think there may be something wrong with the internal memory, or something.
  6. #5
    Join Date
    Dec 13th, 2009
    Location
    Indiana
    Posts
    717
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Im assuming you have done a hard reset. Smart card is the first thing to look at. Cabling would be my second. Is there a switch involved? I have had LNBF's go bad...only one port on the LNB working fine. (2 rcvrs, one good one bad...turned out to be the LNB). Ground block ok? What caused the last one to fail?
    Last option would be to try a new receiver.
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! dahenny did! Help Support The Site And Get Rid of the Syndicated Ads, dahenny did! If you enjoy the site consider supporting it, dahenny did! Be COOL like dahenny and Click a Star and become a Supporting Pub Member today!
    Join Date
    May 11th, 2007
    Location
    Boone, North Carolina
    Posts
    2,730
    Post Thanks / Like
    ADVERTISING BOX
    Quote Originally Posted by GaryPen View Post
    Anytime that you unlock the system, you have to "create a password" to re-lock the system.
    An eye for an eye, a tooth for a tooth...people that espouse this doctrine end up blind, and toothless!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
