Page 1 of 3 123 LastLast
Results 1 to 6 of 13
Thread: New Dish install What Sats and What transponders should I get
  1. #1
    Join Date
    Dec 18th, 2004
    Posts
    73
    Post Thanks / Like
    Recently I swapped out Dish for Direct TV.
    I installed a slimline 5 transponder dish and LNB. I believe I'm getting all the stations I'm supposed to get but am not clear on what sats and what transponders I should be seeing. I do not care about locals. I'm in Alabama
    Currently I get the following: (it is Raining)
    99c = 1-14 SS= 24-44.
    99s = 1,3,5,17,18,21,22 SS = 25-83
    103s = 16,18,19,20 SS = 21-56
    103ca = 9-22,24 SS= 24-52
    103cb = 1-14 SS= 32-51
    101 = 1-3,9-11,12-19,21-32 SS= 82-100
    110 = 8,10,12 SS= 77-82
    119 = 22-30,32 SS=25-98
    All Tuner 1
    Is there any sat I should tweek?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! charper1 did! Help Support The Site And Get Rid of the Syndicated Ads, charper1 did! If you enjoy the site consider supporting it, charper1 did! Be COOL like charper1 and Click a Star and become a Supporting Pub Member today!
    Join Date
    May 18th, 2004
    Location
    I'm Nationwide
    Posts
    18,443
    Post Thanks / Like
    I think you mean just a 5 LNB dish
    I think you would see very soon if you weren't setup correctly, but post your individual signal strengths (on a non-rain day) for us to see.
    I would say 101 (the main or "home" SAT) should be at or over 98 easy across the board. But if you can post all the reading out it will make it a lot easier.
    DirecTV HR22, H21, H23, HR20, Sanyo PLV-Z 119", Acer H5360 106", Samsung PN51D450 51", Insignia NS-51P680A12 51", Onkyo TX-NR708, Onkyo HT-R550, Yamaha RX-Z, Sony BDP-S570, Sony PS3 (x2), D-Link Gigabit Network, ViaTalk Unlimited Everything VoIP ($13/mo)
  4. #3
    Join Date
    Dec 18th, 2004
    Posts
    73
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by charper1 View Post
    you are right 5 LNB. I have never gotten 101 for all sats to be over 98 even with a Round dish and 2 LNBs. I will post when the weather dries up. For reference I have.
    Tuner 1
    85,84,82,0,79,95,82,93,
    79,94,82,0,83,96,77,95,
    75,99,77,0,92,93,84,95
    83,89,80,96,82,95,81,95
    Tuner 2
    85,85,84,0,80,94,81,95
    91,88,86,0,85,94,83,95
    79,99,83,0,88,95,86,95
    85,89,82,96,82,95,82,95
    each varies 1-3 counts either way.
  5. #4
    raoul5788's Avatar
    raoul5788 is online now Studebaker driver
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Dec 28th, 2004
    Location
    Cheshire CT
    Posts
    15,661
    Post Thanks / Like
    There are a couple of spot beams on 101, so you won't get high numbers on all of the transponders, but you should be in the mid 90's or better on most of them. The same for 110 and 119. On 99c and 103c you should be mostly in the 90's or upper 80's. 99s and 103s are spot beams and only the ones aimed at you will be in the 80-90 range. Even with the rain your numbers indicate that your dish is out of alignment.
    BTW, my name is Chip, Raoul5788 is just a screen name
  6. #5
    Join Date
    Dec 18th, 2004
    Posts
    73
    Post Thanks / Like
    Thread Starter
    What is the recommended way to tweek the dish? Should I concentrate on 119 or 110 ? The lowest transponder? Do I need to care about the other sats? I get my locals OTA.
  7. #6
    Join Date
    May 18th, 2004
    Location
    I'm Nationwide
    Posts
    18,443
    Post Thanks / Like
    I would make 100% sure the dish is mounted plumb & level
    Make sure the skew(tilt) and elevation are set correctly.
    Then tweak the azimuth a bare bump at a time. All I have ever used is a $12 map compass to get started and then the receiver's meters.
    I simply focus on pegging out 101; all mine are 98 + (where applicable) and the other SAT fall in line.
    Other can tell you there methods also. It really is trail and error and then you will get the feal of it.
    http://manuals.solidsignal.com/Sliml...ion_Manual.pdf
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
