Page 1 of 2 12 LastLast
Results 1 to 6 of 9
Thread: Pointing a 1000.4 western arc dish
  1. #1
    Join Date
    Mar 6th, 2011
    Location
    CHICAGO
    Posts
    Post Thanks / Like
    I am trying to point a 1000.4 western arc in the chicago area. I was unable to find the angles. I was able to find the angles for 1000.2 are the the same? I was unable to get signal with these. I also have 2 dpp44 switches in attic so I can hookup 6 boxes. Some legacy some new. Should I run a cable to only 1 box for setup? I have a small signal finder that I using to tune. Had no trouble tuning dish 500 before the dpp44 switches in attic.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Aug 19th, 2005
    Location
    Some old corn field, United States
    Posts
    1,362
    Post Thanks / Like
    Need to know what number of receivers you are attempting to install.. the settings for a 1000.2 and 1000.4 WA are the same.
    If you are hooking up the DPP44 switches you need to run 3 cables from the dish to the switch.
    Connect meter and point the dish slightly to the SW then SLOWLY move dish Back and forth until you hit a signal. Peak the signal then run a switch test. If you get 119, 110 ,129 in that order you are good to go. if you get 110, X, 119 you are too far to the East.
    Sometimes I miss the old days when we had three channels on the TV. Back then, I went to bed at a decent time.
  4. #3
    Join Date
    Sep 10th, 2009
    Location
    HOCKEYTOWN
    Posts
    971
    Post Thanks / Like
    do you have a western arc lnb?
  5. #4
    Join Date
    Mar 6th, 2011
    Location
    CHICAGO
    Posts
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by the mack View Post
    Yes I do. I got a signal today but was unable to get all three. I hit 110 and 119 but not 129. I ran a separate cable to dish for pointing. i am going to check my mount and settings.
  6. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! HIFI did! Help Support The Site And Get Rid of the Syndicated Ads, HIFI did! If you enjoy the site consider supporting it, HIFI did! Be COOL like HIFI and Click a Star and become a Supporting Pub Member today!
    Join Date
    May 9th, 2007
    Location
    surfin SATGUYS in a round room with padded walls
    Posts
    8,863
    Post Thanks / Like
    Gamer IDs
    PSN ID: hifi454
    where are the sats located in your switch matrix screen?
    In the end we're all just chalklines on the concrete
    Drawn only to be washed away
    For the time that I've been given
    I am what I am
  7. #6
    Join Date
    Sep 10th, 2009
    Location
    HOCKEYTOWN
    Posts
    971
    Post Thanks / Like
    Quote Originally Posted by HIFI View Post
    you should have 119,110,129 in that order....if 110 is first you are about 10 degrees off...if you have 119,110,xx you may have a obstruction blocking 129.
    the 129 sat is pretty low in the sky....
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
