Results 1 to 6 of 20
Thread: VIP 222K and External Hard Drive
04-14-2011 12:22 PM #1
I am confused. The My Equipment page at the Dish site says you can't use an EHD on the VIP222k. The manual that comes with it says you can. I enabled the external device in the receiver setup.
I contacted Dish support and asked for external device recording to be enabled. I was told it was already enabled on the receiver (purchased new last week). I asked the tech rep to confirm that I can record to an external drive and he said yes.
I have a 500 Gb externally powered drive plugged in to the USB port on the back of the receiver. I set up a timer event for the EXT device. Nothing happens.
Am I doing something wrong? Or do I have wrong information? Any help would be greatly appreciated.
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
04-14-2011 12:22 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
04-14-2011 12:26 PM #2
Wrong information. The DVR Conversion is not available at the present time for the 222/k receivers. From the sounds of it, Dish may never offer this upgrade.
04-14-2011 05:20 PM #3
- Join Date
- May 5th, 2006
- Location
- Cancun, Mexico
- Posts
- 100
- Post Thanks / Like
- Thread Starter
04-15-2011 10:08 AM #4
- Join Date
- May 5th, 2006
- Location
- Cancun, Mexico
- Posts
- 100
- Thread Starter
04-15-2011 11:01 AM #5
Problem due to dealing with tv2. Been discussed here previously, do not have time to research thread on subject at this time.
04-15-2011 12:06 PM #6Actually the reason posted the most is the limitation of the traffic the USB 2.0 port can handle. Supposedly it would be practical if a 222(x) with a USB 3.0 port were produced which would require an external USB 3.0 enclosure.
ADVERTISING BOX
USB 3.0 SuperSpeed
Features and Highlights
5Gbit/s Bus Speed! There is some spec overhead but speeds of 4Gbits are achievable.
Backwards compatibility with USB 2.0 hi-speed devices.
The new 500MB/s speeds can only be achieved using a USB 3.0 Standard-B plug.
Cable makeup: 2 wires for power and ground, 2 for Hi-Speed backward compatibility, 4 wires for the new Superspeed.
Improved power efficiency! USB 3.0 has no device polling and lower active and idle power requirements.
Register To Reply
