Page 1 of 3 123 LastLast
Results 1 to 6 of 15
Thread: Small Antenna With High Gain
  1. #1
    Join Date
    Sep 15th, 2010
    Location
    Toronto
    Posts
    309
    Post Thanks / Like
    Is there such a thing?
    I am looking into Yagis and Log Periodics for picking up WNGS channel 7, 80 miles away. The design software spits out antenna lengths of 12 to 15 feet for this wavelength but I really don't want something so big.
    Does anybody know of a type of antenna that will give something like 12 dBi gain in a smaller package, like 5 feet long?
    My intuition is that the physics involved make it impossible but I would love to be proven wrong!
    Regards
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Sep 7th, 2003
    Location
    Thiepval
    Posts
    1,338
    Post Thanks / Like
    I've installed this Philips antenna for customers;
    Amazon.com: Philips SDV2940/27 UHF Digital and Analog Indoor/Outdoor TV Antenna: Electronics
    It's actually amazing for its size. Your local WalMart has them in stock.
  4. #3
    Join Date
    Aug 18th, 2008
    Location
    Northern Va
    Posts
    269
    Post Thanks / Like
    Quote Originally Posted by Mike500 View Post
    The OP is looking for a VHF antenna. The Phillips is UHF only & amplified, which is completely wrong for his situation. An amplified antenna in Toronto would be like using gasoline to start a charcoal grill.
  5. #4
    Join Date
    Aug 18th, 2008
    Location
    Northern Va
    Posts
    269
    Post Thanks / Like
    The shortest antenna that I know of that provides around 12 dbi gain is the
    Winegard YA-1713
    at 8.3 feet. To get up to
    13 dbi gain
    the size goes up a lot more. Unfortunately you can't fight the laws of physics when dealing with fringe VHF.
  6. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Iceberg did! Help Support The Site And Get Rid of the Syndicated Ads, Iceberg did! If you enjoy the site consider supporting it, Iceberg did! Be COOL like Iceberg and Click a Star and become a Supporting Pub Member today!
    Join Date
    Nov 17th, 2003
    Location
    Parts Unknown
    Posts
    89,735
    Post Thanks / Like
    The shortest antenna that I know of that provides around 12 dbi gain is the Winegard YA-1713 at 8.3 feet
    thats the antenna I use for a distant VHF and it works great
    FOLLOW THE BUZZARDS.....
  7. #6
    Join Date
    Apr 30th, 2008
    Location
    Aurora, CO
    Posts
    128
    Post Thanks / Like
    Quote Originally Posted by rogerduncan100 View Post
    One antenna fits within your dimensional requirements: AntennaCraft's Y5-7-13. (Winegard's competing model, YA-6713, has been discontinued.) The Y5 will only get you to maybe 9 dBi of gain, which is about half of what you seek. Therefore, you'll need to deploy other strategies for getting that last three dBi:
    More height above ground level. The classic rule of thumb is that every additional 3 metres of height is worth about another decibel of gain. This factor can be dependent on the intervening terrain, and occasionally, more height doesn't help at all. (On the bright side, this isn't usually the case in flat areas such as the Toronto-Buffalo lake plain.)
    Different location on the roof. Signals have horizontal-plane "hot spots" whose sizes vary inversely with increasing frequency. In other words, you can move a UHF antenna several centimetres laterally to find (or lose) a hot spot, but it can take a couple of metres, or more, to achieve the same effect in mid-VHF frequencies such as channel 7. This strategy will require quite a bit of experimentation. Translation: You'll likely be up on the ladder and/or roof repeatedly.
    Use a Jointenna or signal injector with the dedicated VHF antenna. The antenna will pick up signals from many other channels besides the one you want in a heavily saturated market like Toronto. Together, they will interfere with the weak signal you seek, even if they're on other channels (and even the FM band!). Think of this device as a "collar" that lets channel 7's signal through while attenuating everything else on both sides of channel 7. Channel Master
    Jointennas
    are inexpensive, but their F-connectors have a bad reputation for snapping off under anything more than the slightest pressure; Tin Lee Electronics right in Toronto makes high-quality
    signal injectors
    , but you'll pay dearly for their custom work.
    • Finally, a low-gain pre-amplifier added to the VHF antenna might help to counteract cable losses, but note that you will need to insert the amp and its power injector before a Jointenna/signal injector to avoid creating other reception headaches.
    All of this is a very roundabout way of saying you'd probably be much better off compromising on those dimensions by getting the YA-1713 everyone else recommends and feeding it into a Jointenna/signal injector...
    Last edited by Don_M; 05-01-2011 at 12:36 PM. Reason: Metric instead of English measurements.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
