Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: circular lnb to linear lnb convert
  1. #1
    Join Date
    May 22nd, 2006
    Posts
    76
    Post Thanks / Like
    Question circular lnb to linear lnb convert
    I got this rarely seen lnb, round shape, ku band circular single lnb, lo=10.750 Ghz, Input=11.70-12.75 Ghz, NF=0.5 dB
    seems like the frequency (11.70-) is fine for fta, however the circular polarization is a problem
    thinking of taking off the front cap and removing inside the plates to make it linear
    would this work ?
    thanks !
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Nov 9th, 2009
    Location
    canada
    Posts
    791
    Post Thanks / Like
    That lnb is made for "eye-patchers" to get 118w and 119w on the same lnb....not sure if its possible to get linear TPs with it....
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Iceberg did! Help Support The Site And Get Rid of the Syndicated Ads, Iceberg did! If you enjoy the site consider supporting it, Iceberg did! Be COOL like Iceberg and Click a Star and become a Supporting Pub Member today!
    Join Date
    Nov 17th, 2003
    Location
    Parts Unknown
    Posts
    89,850
    Post Thanks / Like
    Had one like that when they first came out.....pile of crap in my opinion
    I gutted mine and took out the dialetic plate in the middle then it worked fine on linear. Found the post
    http://www.satelliteguys.us/106170-d...ml#post1044115
    FOLLOW THE BUZZARDS.....
  5. #4
    Join Date
    Sep 22nd, 2005
    Location
    L.A., Calif.
    Posts
    11,799
    Post Thanks / Like
    High production circular LNBFs have a little fin inside the feed tube to make 'em work on circular.
    It's cast into the metal.
    If your unit is made with that technology (instead of the teflon plate), then you'd have to remove the metal with a hand grinder.
    So, agreeing with Iceberg, I wouldn't pay real money for one.
    Of course, if you found one for free, by all means take a look.
    Straight Talk on AT&T iPhone 4, iOS 5.0.1, BB 3.10.01.
    restoring broken iPhone 4S, iOS 6.1.3, BB 3.4.03.
    : BirdView 8' solid & GBox V3000.
    AMCI 8' perf (maybe a DH?) & AJAK-180.
  6. #5
    Join Date
    May 22nd, 2006
    Posts
    76
    Post Thanks / Like
    Thread Starter
    circular lnb to linear convert
    removed white front plastic cap (with a help of heat gun)
    inside is a white piece of plastic , placed in a 45 degree angle
    on both end , a wide "V" shaped cut out, almost as wide as the plastic
    removed plastic piece
    behind at 3 o'clock there is a round metal pin goes horizontally until halfway
    further in, at 6 o' clock there is another round metal pin vertically up about 1/3
    above it, a larger diameter horizontal pin goes all the way across between the metal walls
    I am going to try it out with plastic piece removed, point it to the strong 101w and see what happens .....it was free, nothing to loose
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! rv1pop did! Help Support The Site And Get Rid of the Syndicated Ads, rv1pop did! If you enjoy the site consider supporting it, rv1pop did! Be COOL like rv1pop and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 15th, 2007
    Location
    South Central Cascade Mountains and on the road.
    Posts
    2,641
    Post Thanks / Like
    That should do it
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
