Quantcast
Dish 500 Plus to 1000.4 Conversion Kit
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 5 123 ... LastLast
Results 1 to 6 of 29
  1. #1
    Join Date
    May 14th, 2004
    Posts
    293
    Post Thanks / Like
    I have a 500+ that I`d like to convert to a 1000.4 configuration. I know that there is a conversion kit as specified in the 1000.4 Installation Manual.
    Where can I purchase this kit?? I`ve tried Sadoun and can`t seem to find a vendor who carries this kit. Has any forum member made this conversion and can offer comments on ease of assembly and alignment?
  2. #2
    Join Date
    Dec 1st, 2008
    Location
    On Your Roof!
    Posts
    910
    Post Thanks / Like
    i have not seen a 500+ to 1000.4 kit as they do not exist !
    You can take a 1000.4 WA or EA lnb and yolk and install it on a 500+ to get 119,110,129 (WA) or 77,72,61 (EA)
  3. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Claude Greiner did! Help Support The Site And Get Rid of the Syndicated Ads, Claude Greiner did! If you enjoy the site consider supporting it, Claude Greiner did! Be COOL like Claude Greiner and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 8th, 2003
    Posts
    6,125
    Post Thanks / Like
    Doesn't exist.
    The Dishes are so cheap these days, you can buy a 1000.4 from Dishstore for $79
    Claude Greiner
    In Memory of Tiger Stadium
    April 28th 1896 - September 21st 2009
  4. #4
    Join Date
    Dec 1st, 2008
    Location
    On Your Roof!
    Posts
    910
    Post Thanks / Like
    you going to toss in the yolk for free claude?
  5. #5
    Join Date
    May 5th, 2006
    Posts
    306
    Post Thanks / Like
    Quote Originally Posted by cspiteri View Post
    That "conversion" would be a complete replacement of the antenna and mast (different diameters as mentioned on this site).
    There is a conversion from 500+ to 1000+ that adds the third LNB: Just a bracket and a DishPro single or dual LNB. I couldn't find any kits with a quick web search so you may need to purchase separately.
    Depending on what you have for a switch right now you may also need to upgrade the switch to at least a DPP33 if you don't need 118 or a DPP44 if you need all 4 satellites. Both about $50 street price for new.
    Here's the bracket part of the conversion:
    NEW DISH NETWORK 129 BRACKET FOR DP 500+/1000+ LNBF HDTV | eBay
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    Then you need a DishPro dual or single LNB about $40 new.
    So it may be less expensive to buy an new 1000.4. This comes in a Western arc and Eastern arc version. Saw one on eBay for $60 new.
    I installed a 1000+ back when the original 129 satellite had low signal. It made a big difference over my 1000 (not a .2 or .4). If you don't need to upgrade the switch, adding the 129 LNB is the least expense.
    If you switch to a 1000.4 you'll need to replace the entire antenna, mast and foot as the mast diameters are different. a 1000.2 is the same mast diameter and might be worth consideration.
  6. #6
    Join Date
    May 14th, 2004
    Posts
    293
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Thanks kwindrim - I wasn`t aware that the mast diameter for the 1000.4 was larger. I have a tile roof so changing masts is not a simple matter.
    I`ll probably be better off just getting the 1000.2 as I would need a switch, bracket and lnb which would cost as much or pehaps
    more than a complete 1000.2 dish.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
