Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: how to adjust a slim directv dish?
  1. #1
    Join Date
    Dec 31st, 2008
    Location
    usa
    Posts
    198
    Post Thanks / Like
    Hi guys
    i always have some problems with the realign of a slim 3 sats (101,103,99)
    i'm using a old birdog 2.5 with a standard 3 satellite slim, but i got 101 ka/ku good but no enough with the 99 or 103 when i try to activate always i have to realign the dish more that three times. any comments will be helpfull .do i have to realign the two bolts ( for elevation and azimuth) is this always i haveto do it??
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Jimbo did! Help Support The Site And Get Rid of the Syndicated Ads, Jimbo did! If you enjoy the site consider supporting it, Jimbo did! Be COOL like Jimbo and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 14th, 2005
    Location
    NW Ohio - Buckeye Country
    Posts
    47,176
    Post Thanks / Like
    If you have the 101 nailed, mid 90's and can't get the 99 or 103 then your TILT is probably off, also make sure that your mast is PLUMB, that is the most important part, if the mast is not plumb, you'll get the 101 and the rest will be off.
    Lets Go Red Wings !!!
    HR44-500, 2 HR24-500's, 2 HR24-100's, SL3 Dish, SWM Dish, AM21, 60" Pioneer Elite, 2 - 42" Pioneer Elite's, Sony BDP-S790
    Thinking of signing up for DIRECTV? Please PM me for my DIRECTV account number and we can both save $100 on our DIRECTV bill!
  4. #3
    raoul5788's Avatar
    raoul5788 is offline Studebaker driver
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Dec 28th, 2004
    Location
    Cheshire CT
    Posts
    15,633
    Post Thanks / Like
    It sounds like your mast may not be plumb. Check it carefully, it's important! Set the skew and elevation like the menu says but keep the azimuth bolts loose. Swing the dish slowly and when you get a strong signal on the 101, tighten the bolts enough to keep the dish from moving easily. Make adjustments enough to get the numbers on 101 in the 90s. Then check 99 and 103. Hopefully you will show some signal there, too. Push lightly on the back of the dish on all four "corners" and see what that does to the signal strength numbers. That should tell you which way to make the fine adjustments. You should be able to get them in the upper 80s and 90s. Good luck and don't give up! Get back to us and tell us how it went.
    BTW, my name is Chip, Raoul5788 is just a screen name
  5. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! charper1 did! Help Support The Site And Get Rid of the Syndicated Ads, charper1 did! If you enjoy the site consider supporting it, charper1 did! Be COOL like charper1 and Click a Star and become a Supporting Pub Member today!
    Join Date
    May 18th, 2004
    Location
    I'm Nationwide
    Posts
    18,443
    Post Thanks / Like
    ditto for mast not level and/or plumb
    DirecTV HR22, H21, H23, HR20, Sanyo PLV-Z 119", Acer H5360 106", Samsung PN51D450 51", Insignia NS-51P680A12 51", Onkyo TX-NR708, Onkyo HT-R550, Yamaha RX-Z, Sony BDP-S570, Sony PS3 (x2), D-Link Gigabit Network, ViaTalk Unlimited Everything VoIP ($13/mo)
  6. #5
    Join Date
    Jul 14th, 2005
    Location
    Posts
    47,176
    Post Thanks / Like
    Quote Originally Posted by raoul5788 View Post
    Snug up the bolts before you push on the sides so that you don't lose your signal you just found.
    Once you have signal on all three, use the adjustment bolts to fine tune it further if needed.
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! stardust3 did! Help Support The Site And Get Rid of the Syndicated Ads, stardust3 did! If you enjoy the site consider supporting it, stardust3 did! Be COOL like stardust3 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Mar 7th, 2006
    Location
    NE TN
    Posts
    4,308
    Post Thanks / Like
    You should use the signal to noise function on that birdog. Once locked & found on 101 press the on button once, that will put the meter in that mode. Peak it out in that mode & it will help you, it is much more sensitive. Again, a plumb mast is imperative, if skew is calling for 66 it better be 66, 1 or 2 degrees off on skew is the difference between passing or failing.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
