Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: How Do I Check Amp/Preamp Operation?
  1. #1
    Join Date
    Mar 14th, 2005
    Location
    Valdosta, GA
    Posts
    11
    Post Thanks / Like
    Decided to start over with the OTA antennas. I replaced my old RadioShack VHF/UHF with a Terk 44 and was gettting several stations "okay" and one of them HD. Since all of my local HD stations are broadcasting from the same degree (+/- 1 degree) I decided to upgrade and get a little more directional in hopes to gain more of the available HD channnels.
    I put up a Channel Master 3020 with a Channel Master Spartan 3 3041DSB Amp/Preamp. Here is my problem:
    I notice NO difference when the amp is plugged in or bypassed.
    I get fewer stations
    Could the amp/preamp be bad out of the box? How do I check? Would I be better suited using a Titan2 7777?
    Setup-
    I run RG6 all the way. Antenna to Diplexer to DirecTV Triple LNB to 25' RG6 to Diplexer to DirecTV D10. I run a splitter off the TV end of the diplexer - one RG6 to D10 Ant In and the other RG6 to TV (Sony 32" WEGA HD Ready). HDMI from D10 to TV.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Kevinw did! Help Support The Site And Get Rid of the Syndicated Ads, Kevinw did! If you enjoy the site consider supporting it, Kevinw did! Be COOL like Kevinw and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 2nd, 2003
    Location
    Charlotte, NC United States
    Posts
    2,964
    Post Thanks / Like
    Sounds like someone has been to Lowes. My suggestion would be to take the diplexor out of the picture and run a straight line to the Amp then to the TV from the amp.
  4. #3
    Join Date
    Mar 14th, 2005
    Location
    Valdosta, GA
    Posts
    11
    Post Thanks / Like
    Thread Starter
    Lowes it was! Very limited to our Channel Master dealers here in South Georgia.
    So am I to understand that the diplexer diminshes the effect of the amplifier? And if so, how? Just trying to get a better understanding of the situation.
  5. #4
    Join Date
    Dec 2nd, 2003
    Location
    Posts
    2,964
    Post Thanks / Like
    This might explain it better
    http://www.starkelectronic.com/allamps.htm
    All pre-amps have a power supply that plugs into an AC outlet inside the house that lowers the voltage and sends it up the coax to power the amplifier which is mounted up near the antenna. The benefit is that you get amplification before any line loss or noise and you don't have to run 117 AC up to your roof. NOTE: Don't install a regular splitter between the power supply and the pre-amp or you will short circuit the system and it won't work. You can install a special splitter that is power passive on only one port. Or put a DC Block on the outputs that don't run to the power supply. Also you can't put any type of matching transformers between the power supply and the pre-amp.
  6. #5
    Join Date
    Mar 14th, 2005
    Location
    Valdosta, GA
    Posts
    11
    Post Thanks / Like
    Thread Starter
    Thanks, Kevinw.
    One more thought/question. I run my RG6 through a surge protector before it gets to any equipment. Any problems here?
  7. #6
    Join Date
    Mar 14th, 2005
    Location
    Valdosta, GA
    Posts
    11
    Post Thanks / Like
    Thread Starter
    Thanks again, Kevinw. Followed your advice and ran separate lines. Works great.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
