Results 1 to 6 of 11
02-07-2012 02:23 PM #1
02-07-2012 02:23 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
02-07-2012 03:27 PM #2
Over here at 79.3 even with 30W sat higher in the sky with lots of bumps and trees no hope at all in pointing that far east. I think you lucked out with flat land and no trees.Then again... you get tornadoes.
02-07-2012 04:52 PM #3
boy if you got any snow that sucker would be buried
Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
All FTA stuff in storage right now
02-07-2012 05:47 PM #4
I like it. Has it been reliable for you motoring over that far east?
Friends of Montana PBS
02-07-2012 06:54 PM #5
lt looks like your view east is completely unobstructed. My longitude is 81.6W, and I can get 15W fine... that's the equivalent of you being at 96.4W and receiving 30W. When I point my dish at 15W, it looks just like the pics you posted.
02-07-2012 07:24 PM #6
- Join Date
- Apr 26th, 2006
- Location
- 40 miles NW of Omaha. Omaha?
- Posts
- 4,571
- Post Thanks / Like
- Thread Starter
Toucan-man,
ADVERTISING BOX
Thank you. Yes, the signal is strong and the channels pop in everytime like a snap! I usually watch Cubavision on TP 11884 V (signal quality is currently showing 80% on my AZBox).
Tonight I am logging in 21 active TPs with 61 ITC TV and 58 ITC RADIO channels. The weather is not the best for scanning right now, but it is fair. Since I do have to look through a lot of the atmosphere it does diminish the signal quality at times when it is heavy overcast or raining.
Ice,
Originally Posted by Iceberg
It is definitely low to the ground, but when we get lots of snow, we usually also get LOTS of wind. The dish is in quite an open area of the yard and the wind blows all the snow away from the base of the dish. It's kinda "self-cleaning". Bad part of where it is located is that certain times in the spring, the wind direction (and strong gusts) hit my dish at just the right angle and starts it "fluttering". The dish and the LNBF support begin to set up their own harmonic vibrations and if they are not in sync, I can detect quick blips in the signal quality that cause the video and audio to drop out for a split second. At times, this can be very annoying.
Andrew,
At my location, I would only have a LOS to as far as 20°W, but I won't get there with my motor. I would have to set up a fixed point dish to test the sats between 20°W and 30°W. I am almost at the physical limits of the motor travel when at 30°W and I can only go a degree or two more.
RADARLast edited by AcWxRadar; 02-07-2012 at 07:43 PM.
Register To Reply
