Quantcast
What type of LNB is this?
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 3 123 LastLast
Results 1 to 6 of 18
  1. #1
    Join Date
    Nov 9th, 2009
    Location
    canada
    Posts
    787
    Post Thanks / Like
    is this LNB the same as a dish pro twin LNB but has 4 outputs instead of two?
    DISH500 DISH NETWORK/BELL 500 SATELLITE+QUAD LNB SW44 | eBay
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    can this be used with a DPP44 switch on a Bell system?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Oct 27th, 2008
    Posts
    674
    Post Thanks / Like
    It does have 4 outputs but it is a legacy switch. It will work for Bell but not with any DP & DPP switches. You cannot hook it up to your DPP44 switch and get it to work.
  4. #3
    Join Date
    Nov 9th, 2009
    Location
    canada
    Posts
    787
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by QCK View Post
    is this a new type of lnb? i have never seen this before....is it likely to be currently installed on a bell system? i have a customer wanting to hook up more receivers, i just took a very quick look at his dish and from a quick glance it looked like a dish pro twin, he already has 2 cables going into the basement so i have ordered him a DPP44 switch to put in the basement, now im a bit concerned that his LNB could be this quad type, i guess the only way to verify is to remove the LNB from the dish and see how many outputs it has? i am trying not to make myself look like an A$$ infront of this customer
  5. #4
    Join Date
    Oct 27th, 2008
    Posts
    674
    Post Thanks / Like
    It is called "legacy" for a reason, it is older than DP and DPP equipment. Bell came out with a DPP Quad, but you must get it through them.
    Get him this LNB and the two lines can then go to the DPP44 switch and all will be fine.
    Amazon.com: NEW Dish Network Dish Pro Plus DPP TWIN LNB / LNBF PRO FTA: Electronics
  6. #5
    Join Date
    Nov 9th, 2009
    Location
    canada
    Posts
    787
    Post Thanks / Like
    Thread Starter
    Get Rid of this Ad! Register Today!
    Can the quad output be used with seperators?
  7. #6
    Join Date
    Oct 27th, 2008
    Posts
    674
    Post Thanks / Like
    ADVERTISING BOX
    The DPP Quad you can get from Bell can be yes. The Legacy Quad you posted cannot. You can use DPP separators off of your DPP44 switch so you will be fine using the LNB I posted.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
